1972 454 conversion to serpentine
I've acquired a '74 frame in near-perfect condition and have modified it to the '72 frame physical specs (minor changes here-and there), chemically stripped it, metal prepped and POR15ed it inside and out. Currently removing and replacing the rockers (not my fondest endeavor) and performing a full frame rebuild with new bushings, springs, hardware and so on. I Have a Tremec 5-speed kit coming along with a hydro-boost and steeroids kit as well. Lots of other things going on with it as well and once I get in the swing of things, I hope to post and share my wins and losses with everyone.
However, I have a situation that has me stumped.. I have read numerous postings, but have yet to develop a plan that works for me as there are many options and numerous open-ends.
For no particular reason, I would like to convert the 454 v-belt drive to a reliable and low-cost serpentine system that fits in the '72 with little or no modification/interference. After we finished the rebuild, the engine dyno'd at 460hp with somewhere just north of 500 ft/lb torque; if I recall correctly.
So, any and all input and guidance on how to accomplish this task, what to buy, where to buy and so on would be appreciated.
Thanks!
In this pic you can see the “triangle” bolt pattern on the heads, and the two vertical bolt holes alongside the lower part of the timing cover. The plates bolt here, then the brackets bolt to threaded holes in the plates.
You can see the triangle plates in the next two pics:
The brackets in place:
You can see here how the brackets being spread out give some additional hood clearance:
Looks like a factory install....kinda!
do the BB's sit higher in the engine bay? I used factory bolt holes when I bolted my third gen Fbody brackets on my engine and have no hood clearance issues with a stock 79 L82 hood.
If the ignition timing was dependent on that belt, maybe. But for a SBC engine? Too much expense for me.
But, your set-up looks really good!
Main Rule-------Pull-A-Part (salvage yard=70% discount!)
No special brackets are needed....however you can buy one suggested by other members to avoid adding spacers behind components to align the pulleys faster........if you have the extra cash.
Look for early model big-block engines with serpentine drive pulleys (you also may be able to use 350SBC pulleys).
Alternator pulley(alternator may need spacers to get pulley to sit in same plane as the other pulleys)/ $5
Waterpump pulley/ $5
P.S. pulley if needed/ $5
Crank pulley/ $10
Belt Tension pulley assembly/ $10
Smog pump pulley if needed/ $5
idler pulley $5
Assorted nuts/bolts/spacers $20
Can of black spraypaint $6
Serpentine belt $20
*Parts store---New reverse flow water pump of your choice* $??
Re-drill holes in pulleys as need to fit engine components.
Position the idler pulley to cause serpentine belt to wrap around waterpump pulley more than it normally does to prevent slippage.
Did I forget anything.....
