new motor install
The engine was rated at 375 hp. The dyno specs. came in at 417 @ 5600 rpm. (I will attach spec sheets)
I work out of town quite a bit so Im trusting a local garage to get the motor installed. I have been using the for a few years now and they have not let me down on this car and my other rides.
With that being said i would have loved to do this on my own but unfortunately time constraints and being on the road a lot I don't get much time.
Since the engine has been removed I figure better have the transmission gone threw to. It's an automatic trans L-48 package. The transmission shop rebuilt it and was told about the motor going in and said they replace the converter with a high performance one made for corvettes? I will find out the specs on this tomorrow.
I purchased the car about a year ago and have gone threw all the electrical, brakes, suspension.
This is the first corvette that i have owned at thought i was getting a good deal on the car. After digging into it there was quite a bit going on with it. I've got almost all of it corrected. There was a time i thought to cut bait but I just couldn't do it. I have become wiser for future purchases.
The rear end is stock and I have not changed anything other then bushing and joints. I hope i have made the right decision in this motor, I'm sure it will be better then the factory Hp.
Thoughts???
DUB
That is less than I paid to re-build my own block. The roller cam 355 has similar specs to my 350 and still only $3400. If it lasts, you're solid.
Was your engine dynoed with your carb and distributor?
Your new engine makes great peak power and looks great on the dyno sheet. But your car doesn't start at 3000 RPM like the dyno sheet. As a matter of fact it will spend over 90% of it's life below that. It is a good match for a manual trans with 3.70 gears. It is a mismatch with an automatic with stock convertor and 3.08 rear gearing. Your engine will not have the power or torque of your old engine at lower rpms. This will make throttle response and off the line acceleration worse than your L48. Once you get into the powerband of the cam (likely about 2200 rpm) you will surpass the power the l48 made by an increasingly wider margin as RPM increases. But not being able to roast the tires on launch and getting smoked by a Honda for the first block after you install a 400+ HP engine sucks. So the key is to get into the powerband faster. This is where gearing and a manual trans or higher stall convertor come in.
If your distributor is OEM and has the factory curve your leaving a lot of bottom end and throttle response on the table. You can do a performance recurve your dist for under $20 and a couple hours work.
You also need a vacuum can swap, and some carb jetting changes to actually see the extra power. Email Lars at V8FastCars@msn.com and ask for his most recent recurve paper and vacuum can sheet and instructions.
By raising the stall speed, or slippage, a performance converter raises engine rpm at launch, which increases power at launch. For example, if an engine makes 100 lb-ft of torque at 1,500 rpm and 175 lb-ft at 2,500, which would you rather have? With a higher-stall converter, your engine isn't making any more power, but it's allowing the motor to get to a place where it's happier more quickly.
Read more: http://www.chevyhiperformance.com/te...#ixzz2qA8KEjtz
Thanks I'm on it! I will order the stall converter today (2400) and look into the recurve of the distributor. I hope this motor wasn't a mistake.
Scott
