Differential play
Old Jan 18, 2014 | 07:49 AM
Ribeye's Avatar
Ribeye
Cruising
Default Differential play
There is play between the pinion and ring gear in my 1979 differential. Can this be adjusted out by resetting the ring and pinion gear, or is it standard to replace the third member with a rebuilt one? The play is about 20 degrees and makes quite a noise when going from drive to reverse and reverse and drive.
Old Jan 18, 2014 | 09:17 AM
7T1vette's Avatar
7T1vette
There should be .005-.008" clearance between pinion and ring, so that the tooth surfaces can be properly lubed. Refer to the Chassis Service Manual and/or the Chassis Overhaul Manual on proper differential set up.
Old Jan 18, 2014 | 06:02 PM
DUB's Avatar
DUB
No easy fix to this. I am sure it more than likely has high miles and obviously age on it. It more than likely needs to be rebuilt.
DUB
Old Jan 19, 2014 | 02:50 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Are you positive that it's excessive backlash between the r&p? My wife used to have a '79, and the differential carrier apparently wasn't heat treated correctly, and the shaft that the spider gears ride on "elongated" the holes in the carrier, causing a "clunk" when the car was shifted into 'drive'.
Also, check the condition of the bushing on the mounting bracket on the nose of the diff.
To Differential play
