Heat Riser Does Not Open on 72'
Old Jan 19, 2014 | 04:12 PM
ZZtop2's Avatar
ZZtop2
Default Heat Riser Does Not Open on 72'
I confirmed the heat riser on my 72' never opens. All the components (i.e. spring) appear to be there, but there is no exhaust out the passenger side even after the car is warm. The counterweight is always in the up or horizontal position (riser butterfly closed).
When I hold the counterweight down (riser butterfly open), exhaust comes out the passenger side, equal to the drivers side like it should.
Why/how in the world did GM design the riser to fail closed!?!
Also, I know I can wire the valve open, but do any of you have an idea what might be wrong with it? Like I said, all of the parts appear to be there and hooked up.
Old Jan 19, 2014 | 04:33 PM
rponfick's Avatar
rponfick
Nothing wrong with wiring it open. At least you know it is open. Car will take just a little longer to warm up or idle to settle down.
I've done it in the past.
Ralph
Old Jan 19, 2014 | 05:25 PM
Alan 71's Avatar
Alan 71
Hi zz,
One thing you can try is to determine if the bi-metallic coil is there and that one end (the outer) is attached to the peg with the spring, and the other end of the coil is inserted in the slot of the rod that the flappers that control exhaust flow are attached to.
Regards,
Alan
Old Jan 19, 2014 | 05:36 PM
mrvette's Avatar
mrvette
Alan above is correct, but how many of our beloved sharks are driven in sub freezing weather??? so to just wire the thing open, or twist it that way, and release the spring, carb/induction will warm up almost as fast, talking maybe a minit here now....
for that matter, I have filled the up/over passage in many a intake mani to block it off with Plaster of Paris.....maybe leaving the intake open enough on the pass side to ensure heat flow to the choke apparatus.....
BUT to keep the carb from frying when the temps outside are ~100f.....
Old Jan 19, 2014 | 05:39 PM
Mike Ward's Avatar
Mike Ward
Even working perfectly, the valve may not open at idle. It relies partially on exhaust pressure to open.
Old Jan 19, 2014 | 05:40 PM
ZZtop2's Avatar
ZZtop2
Originally Posted by Alan 71
Hi zz,
Regards,
Alan
Thanks Alan. The bi-metallic coil is there and attached to the peg with the spring, but I am not sure about the valve end. It appears to be attached as I can see the coil tighten when I move the counter weight. Thoughts?
I still can't believe it is designed to fail closed...perhaps something is installed wrong...
Old Jan 19, 2014 | 06:05 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
I agree with Mike Ward. The heat riser on my 72 is closed at idle even when the engine is at normal operating temperature. The increased exhaust flow when engine RPM's increase allow it to open.
Old Jan 19, 2014 | 06:39 PM
Alan 71's Avatar
Alan 71
Hi zz,
If you disconnect the bimetallic coil from the peg will that let the weight drop and stay down?
Regards,
Alan
Old Jan 19, 2014 | 07:22 PM
ZZtop2's Avatar
ZZtop2
Interesting. I rev'd it pretty good and didn't see it move. I also have the classic symptoms of it staying closed: paint burning off the intake manifold at the cross-over tube. I will take another look and then try pulling the coil spring like Alan suggested and see what happens. Thanks guys.
Old Jan 19, 2014 | 08:06 PM
Mike Ward's Avatar
Mike Ward
The paint burns on all of them.
Old Jan 19, 2014 | 09:36 PM
gcusmano74's Avatar
gcusmano74
I messed with mine for years. I drilled and tapped the counterweight and bolted on extra weight in an attempt to get it to be open more often.
Finally, I changed over to an aluminum manifold and swapped out the heat riser for an open spacer.
Old Jan 20, 2014 | 12:23 AM
7T1vette's Avatar
7T1vette
If you don't NEED the heat riser (car seldom used in very cold weather), just drop the exhaust pipe from the heat riser and cut the butterfly valve off the shaft. That way, it can NEVER be closed on you!! And, you don't have any bailing wire showing....
Old Jan 20, 2014 | 01:45 AM
7t9l82's Avatar
7t9l82
Old Feb 20, 2014 | 12:02 AM
6inarow's Avatar
6inarow
I hope you are able to drive it and enjoy it. Does it still look the same with the new wheels etc?
Old Feb 20, 2014 | 06:54 AM
Blue73Shark's Avatar
Blue73Shark
More info in this recent thread:
http://forums.corvetteforum.com/c3-t...ser-valve.html
Fran
Old Feb 28, 2014 | 10:16 AM
ZZtop2's Avatar
ZZtop2
Update: I unhooked the bi-metallic coil spring to drop the counterweight down (open the butterfly valve) as suggested and then just wired the counterweight in position so it does not bounce around over bumps in the road. It worked great and the car still starts fine on cold mornings. Thanks for the help guys.
Old Feb 28, 2014 | 10:19 AM
ZZtop2's Avatar
ZZtop2
Tom, I still have the new Rev100 Classic wheels on it and it is running and driving great. I have done a lot to improve the driving experience without altering the originality of the car (i.e. only bolt on changes like shocks and composite rear spring with 10" lowering bolts, no cutting/grinding/welding except for relocating the rear parking brake bracket on the trailing arm for wheel clearance).
To Heat Riser Does Not Open on 72'
