What is this part
Old Feb 9, 2014 | 09:07 PM
cal camara's Avatar
cal camara
Default What is this part
What is this part, it has a black, lt brown, blue and yellow wire. You can see it attached to the top of my dash under dash. 4 pin 1972 Convertible.
thanks
cal
&d=1391997828[/IMG]
Old Feb 10, 2014 | 12:29 AM
sgtwallydog's Avatar
sgtwallydog
looks like a blinker mechanism and jeebus do I never ever ever wanna pull the dash and deal with that spaghetti!
Old Feb 10, 2014 | 07:15 AM
Mooser's Avatar
Mooser
I think it's the TCS relay based on the location but that's too many wires
M
Old Feb 10, 2014 | 07:42 AM
Mashman's Avatar
Mashman
What's your serial number? I know early 72's have a seatbelt warning system that automatically comes on, and then turns off after a certain amount of time. Later 72's have seatbelt warning system that is activated by the retractors, and passenger seat sensor.
If its an early 72, it could be the timer relay for the seatbelt system. I don't know when the crossover was, but my December build, 9550, has the later system.
Also, I believe that the seatbelt timer is supposed to be attached to the center top dash support that mounts to the firewall and screws into the top dashpad.
Old Feb 10, 2014 | 07:56 AM
gbvette62's Avatar
gbvette62
Chevrolet part #3996297, is listed as the TCS Spark Relay for the 72 Corvette, as well as other Chevrolets.
Old Feb 10, 2014 | 10:43 AM
cal camara's Avatar
cal camara
That's it. Thanks now I can figure it out.
Thanks again.
Now to find the seat belt buzzer stuff.
Cal
Old Feb 10, 2014 | 11:18 AM
Denpo's Avatar
Denpo
Thanks again.
Cal
If it can help, the seat belt buzzer stuff on my '76 is behind the passenger map tray, tucked again the A-pillar.
Often the connector is there but the buzzer itself is gone.
Old Feb 10, 2014 | 12:46 PM
cal camara's Avatar
cal camara
I'll check, thanks
Old Feb 10, 2014 | 01:06 PM
cal camara's Avatar
cal camara
I'll check,
Old Aug 12, 2024 | 02:58 PM
jpd396's Avatar
jpd396
4th Gear
Default Relay ID
That relay part number 3996297 is for vacuum Advance relay for TCS system
Old Aug 14, 2024 | 06:05 PM
Mooser's Avatar
Mooser
Hopefully they've figured it out by now....
M
Old Aug 14, 2024 | 06:13 PM
69L88's Avatar
69L88
You are responding to a 10 year old thread.
To What is this part
