1977 radiator bleeding
Old Feb 26, 2014 | 11:32 PM
tmacd's Avatar
tmacd
Default 1977 radiator bleeding
Can anyone tell me how I would go about bleeding the radiator of air after replacing a lower rad hose.
Old Feb 27, 2014 | 06:30 AM
MrJlr's Avatar
MrJlr
No need that I can see. It will bleed itself as air will float to the top.
Old Feb 27, 2014 | 07:21 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Feb 27, 2014 | 07:00 PM
DUB's Avatar
DUB
Making sure that your radiator cap is GOOD and is a "CLOSED SYSTEM" 15 lb cap...and that your system is tight and it will hold pressure. Then it will also depend that you have the overflow coolant tank and a good hose going from eh radiator to this tank.
When the engine gets hot and pressure is built up...and the overflow tank has a good amount of coolant in it...when the engine is shut off and is allowed to cool down. Air in the block will expel out into the overflow tank and then the system will draw coolant mix from the overflow tank and fill up the radiator.
DUB
Old Feb 28, 2014 | 08:10 PM
tmacd's Avatar
tmacd
Thanks for the replies guys, I was hoping that was going to be the answer.
Old Feb 28, 2014 | 09:26 PM
7T1vette's Avatar
7T1vette
Just leave the pressure cap off until the engine warms up and the thermostat opens and flows a bit. Then, stick the cap back on it. Everyone makes a big deal out of this. But, it's all too simple.
Old Feb 28, 2014 | 11:24 PM
7t9l82's Avatar
7t9l82
i drill a couple small holes in the thermostat it helps move the air through even before it opens.
Old Mar 1, 2014 | 12:35 AM
CanadaGrant's Avatar
CanadaGrant
I just drill a 1/8th hole to keep a little movement and circulation until the thermostat opens instead of a hit of cold fluid. The C3 system can't be bled. It's full of air. Squeeze your upper rad hose. It's all air. I am fortunate enough to have a 69 427 with an expansion tank and if you put a bit too much in it, the upper rad hose will still be full of air and the expansion tank will puke everything out on the ground just behind the right front wheel...
To 1977 radiator bleeding
