454 balancer
Old Mar 2, 2014 | 07:38 PM
jeffh1973's Avatar
jeffh1973
Default 454 balancer
I have went completely through my 73 454 and noticed the harmonic balancer/damper has dry rot and many cracks. Should I buy aftermarket or is there some place I can send it to for refurbishing?
Old Mar 2, 2014 | 07:58 PM
CanadaGrant's Avatar
CanadaGrant
You can buy a 454 balancer from any GM dealer or parts house. You can go stock or aftermarket. If it's a stock motor I wouldn't spend a bundle on a fancy aftermarket balancer. I don't think anyone repairs them as they are under 75 bucks new.
Old Mar 2, 2014 | 08:06 PM
Jeff_Keryk's Avatar
Jeff_Keryk
http://www.damperdoctor.com/
He did mine; I had him cut timing marks and 90* marks.
Old Mar 2, 2014 | 09:31 PM
lars's Avatar
lars
Just because you see surface cracking of the small, visible portion of the rubber in your balancer does not mean that it's bad. If the balancer has not slipped, and if the timing marks are still accurate, the balancer is more than likely still good and safe.
I have had 2 brand new aftermarket (non-SFI-rated) balancers come apart on me. One of them caused about $1000 in damage to a '64 Vette when it exploded, and the other one put a friend in the hospital with a shattered foot and ankle from the shrapnel from the explosion. Just because a balancer is new does not make it safe or reliable. I would trust a GM stock balancer with minor rubber surface cracking, with no indication of slippage, long before I trust an "economical" aftermarket unit...
Lars
Old Mar 2, 2014 | 09:47 PM
jeffh1973's Avatar
jeffh1973
[QUOTE=lars;1586305635]Just because you see surface cracking of the small, visible portion of the rubber in your balancer does not mean that it's bad. If the balancer has not slipped, and if the timing marks are still accurate, the balancer is more than likely still good and safe.
I have always used the original balancer on other builds, but didn't want to scrimp on this project. I feel your statement is sound and true.
To 454 balancer
