Valve adjustment
When I adjust valves using the procedure in a Chevy Manual it just never works out. I always end having a problem and have to do them over, using EOIC method.
When I have used the Chevy Method the intake manifold has always been on, not allowing me to see and verify the lobe position. Is it me, just doing it wrong. Or is this way of doing it flawed.
Bring#1 TDC compression stroke
Adjust Exhaust valves 1-3-4-8
Adjust Intake valves 1-2-5-7
Rotate engine 360* so that #6 is now at TDC compression stroke;
Adjust Exhaust valves 2-5-6-7
Adjust Intake valves 3-4-6-8
Regards
Regards
That's exactly why he's having a problem. The back-pressure from the lifter is indeterminate... sometimes it's soft... sometimes it's hard. So the point at which the turning pushrod exibits resistance might be when the lifter plunger is just right, or when it's all wrong. The "shake" method determines the correct zero lash on lossey goosey lifters AND on mighty tighty lifters. (I used to give demo's of this in my shop)
Thanks[/QUOTE]
Well rotating it 360 degrees puts you right back where you started
I'm not having a problem setting the preload correctly, and the lifters do not have to be pumped up to set the proper preload.
I'm fully aware of the shake method and the twirl technique to find zero prior to setting 1/8, 1/4, 1/2, 1/3, 2/3 preload what ever happens to be chosen.
My question is reference to a specific technique which is in a GM Chevy manual that specifically states:
Bring engine to #1 TDC on the compression stroke and adjust the following valves.
EX 1 3 4 8 INT 1 2 5 7
Rotate engine 360* so #6 is now at TDC on comp stroke and adjust the
following valves
EX 2 5 6 7 Int 3 4 6 8
This technique has something to do with the base circle and the clearance ramps, it may be acceptable on a stock profile cam like on a 327 350 396 etc. I'm thinking it specifically applies to the exhaust valves being on the clearance ramp just enough so the valve is not even starting to open, but still enough to skew the preload, that you will not be able to use this method with modern cams that have a longer/faster
ramp then than a standard historical stock Chevy hydraulic or solid lifter cam.
With a friend were gonna do a rocker arm swap this weekend on a 454 and were going to yank the intake off and visually look as to what is happening. We have both used this method over the years with unsuccessful results, Always resorting back to EOIC or each cylinder rolled around the firing order and adjusting each cylinder on TDC compression stroke.
With no disrespect intended, no one as taken the time to actually read the question and comprehend it, the assumption was made that I do not know how to set preload.
I've been a Lurker for a long time, I like this forum and would like to
interreact. I'm extremely knowledgeable and enjoy helping. I make no claim to being an expert or a engine builder, hence the opening statement. "that my question was a "why question".
I'll figure it out this weekend and that is a guaranteed fact, because myself and my friend we both want to know. When we do this rocker arm swap were going to yank the intake off and discern were the problem is, with this technique.
Respectfully
http://www.centuryperformance.com/va...procedure.html
I want to know why that version in the Chevy Manual does not work out and creates problems.
Regards
Well rotating it 360 degrees puts you right back where you started[/QUOTE]
No...... it's a 4 cycle engine..... 720 * would bring you back to #1 at TDC compression stroke.
360* simply brings you to #6 TDC compression stroke.
Lars
V8FastCars@msn.com...
I've never had any luck with that method, either. I do use it, though, to get things close enough to get the engine running. Then I adjust each valve while running. Has always been the easy way for me.
Duane
Lars
Regards
Regards
The plunger has to be at the top of its travel.
following valves
Guilty. My apologies.
Respectfully
Goodmorning, yes the plunger has to be at the top of the lifter, and care must be taken not to compress it when setting the preload.
No apology is necessary, it's just a misunderstanding. I probably should have stated my question differently to avoid confusion.
Regards
Mark J Anderson
