1971 coupe T top pad liners
Any feed back would be great..
The best way to recolor those panels is with SEM [liquid] ColorCoat vinyl dye. Purchase it at a local area auto body paint supply store (not an auto parts store). They can mix it to your interior color code or to match a part that you bring in to them (one of the pads you are replacing?). Clean the parts well with detergent (oil, grease, protectant
), rinse all detergent off completely and let dry.If you don't have spray equipment, also buy a $10 Pre-Val bottle sprayer at the store where you are buying the SEM dye. It works GREAT with the vinyl dye. Two light, covering coats of dye is all it takes and they will look like new.
Original panels will fit properly. You might have to re-dye new panels anyway, if the color isn't a really good match with your interior.
This is really easy to do and you will be surprised at how the interior looks when done. You may even want to re-dye all of your interior pieces!!!
My interior is the dark blue..
I did contact SEM products and they got me in touch with the local rep. that's working on finding me someone local that can mix it up for me.
I did ask SEM but they don't sell it directly..
This sounds like a nice find. Generally the original interior soft parts are far superior to the reproduction parts available.
7T1 has good advice on how to proceed in using the dye from his personal experience!
Good Luck!
Regards,
Alan
For my last purchase, I had to contact a store that was about 30 miles away. The guy who mixed it was going to be at a car show I was in a few days later and he just dropped it on me at the car show.
IMO, it is important enough to find the "real deal" on this one. The Forum regularly has folks that have used the "spray vinyl dye" stuff from the aftermarket vendors; they either have problems or show photos of their parts looking like they have been sprayed with $3-a-can cheapo spray paint.
For something that you will be living with for several years (or more), get the right stuff to do the job well...even if it takes some trouble to get it.
For something that you will be living with for several years (or more), get the right stuff to do the job well...even if it takes some trouble to get it.I'm still working with the local SEM rep to see what other stores he provides supplies for. The store he original sent me to can't make up that color code for me in SEM but can in Diamont. I decided to pass and keep looking. The SEM rep said most people are switching to Sure Coat instead of the Color Coat. Do you know if the Sure Coat will work as well?
I don't mind taking a trip to get the right stuff. I just want to make sure I can find it. I'll keep calling. I'm in not big hurry as I still have another 4-6 weeks before thinking about taking the car out..
If you decide to try SureCoat, please let us know how it turned out.
