Dwell changes
Old Mar 15, 2014 | 08:49 PM
Sayfoo's Avatar
Sayfoo
Default Dwell changes
What would cause the dwell to change on a stock '69 points distributor?
Mine changes 3-4 deg when reving from idle to 2k rpm.
Old Mar 15, 2014 | 08:51 PM
TimAT's Avatar
TimAT
Check that the breaker plate is not moving up and down. If it tilts as the advance moves it, it can change the dwell.
Old Mar 15, 2014 | 08:54 PM
63split63's Avatar
63split63
My guess would be worn distributor shaft and or worn bushings .
Bill
Old Mar 15, 2014 | 08:59 PM
TimAT's Avatar
TimAT
Good point- my original TI distributor, the lower bushing was shaped like a football. It's a wonder that the upper bushing was still fairly good.
Old Mar 15, 2014 | 09:25 PM
ctuinstra's Avatar
ctuinstra
Worn distributor or bushings.
Old Mar 15, 2014 | 11:27 PM
Sayfoo's Avatar
Sayfoo
I rebuilt the dist. about 25k miles ago. I replaced the lower bushing. The top was good. I did shim the gear to get the correct clearence. Guess I'll have to check everything again.
Old Mar 15, 2014 | 11:56 PM
ctuinstra's Avatar
ctuinstra
What about the star wheel itself? I'm not sure if it will cause a change or not.
Old Mar 16, 2014 | 12:02 PM
joewill's Avatar
joewill
probably bushings.. could be just an old tired inaccurate meter..
Old Mar 16, 2014 | 01:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
One test that is long forgotten by new mechanics, in regards to dealing with the old school distributors. How to check the distributor for bushing/shaft wear.... and that test is to attach a dwell meter to the distributor and bring up the RPM's. If the dwell increases the distributor needs to come out.
Old Mar 16, 2014 | 01:26 PM
lars's Avatar
lars
It's normal for dwell to decrease slightly as rpm comes up - it's one of the drawbacks of single point ignition systems. A 3-4 degree change may be excessive at 2000 rpm, but it's perfectly normal for dwell to decrease from 30.5 degrees at idle to around 29 at elevated rpm.
If I were you, I'd first install a good set of points. If your points spring is inadequate, is will decrease dwell at elevated rpm. Try a set of NAPA CS786.
Normally, if you have bushing wear or things "flopping around" from wear, you will see fluctuating dwell at any rpm - not just an overall steady decrease as rpm comes up.
Lars
Old Mar 16, 2014 | 05:28 PM
Sayfoo's Avatar
Sayfoo
I will change the points and go from there.
Thanks all.
To Dwell changes
