Install Intake w/ Carb Attached?
Old Mar 16, 2014 | 11:28 AM
79vetter's Avatar
79vetter
Default Install Intake w/ Carb Attached?
What is your opinion of installing the intake manifold with the Carb already attached to it?
Do you think that the extra weight of the carb will push out the sealant too much on the ends of the block?
Old Mar 16, 2014 | 11:31 AM
diehrd's Avatar
diehrd
I doubt it if you let it skim up before you place intake down, but getting to SBC intake bolts may be easier with it off. Unless it is a vortec intake
Old Mar 16, 2014 | 11:50 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Old Mar 16, 2014 | 12:01 PM
MrJlr's Avatar
MrJlr
Good lord.......how much does your carb weigh?!!!
Only problem I could possibly see is it's just more stuff in your way.
Old Mar 16, 2014 | 12:02 PM
gcusmano74's Avatar
gcusmano74
The weight of the carb is not an issue. With the carb attached, however, you will find it difficult to get a torque wrench on the middle bolts of the manifold.
Install the carb later.
Old Mar 16, 2014 | 01:42 PM
7T1vette's Avatar
7T1vette
Simpler if you remove it and tape-over the throttle ports.
Old Mar 16, 2014 | 04:26 PM
John Holmes's Avatar
John Holmes
Did it a hundred times like that.
Torque wrench for intake bolts? Whatever flips yer flipper!
Old Mar 16, 2014 | 04:52 PM
70LQ4's Avatar
70LQ4
I agree , did hundreds of them over the last 40 Years. Never disassembled any more than what was necessary to do the job. Small block Chevys in a Corvette are cake , try doing a Ford FE bigblock in a F150 or a Galaxy . That will make Your ***** drop out of Your pants leg.
Old Mar 16, 2014 | 06:48 PM
qwank's Avatar
qwank
maybe if you had a torque wrench you wouldn't have had to re do it 100 times
Just kidding, I know what you meant
To Install Intake w/ Carb Attached?
