Carburetor Problem?
Old Mar 19, 2014 | 02:36 PM
Rich's'78's Avatar
Rich's'78
Originally Posted by bwinterstine
No. Initial is at 16 with advance hose disconnected and plugged. Vacuum advance adds another 16 for a total of 32 at idle. Mark to shoot for is 36 degrees so I could still add 4 more degrees.
I measured the cruise timing today which is the total of initial timing, vacuum advance and the centrifugal advance. Mark to shoot for is 52 degrees and I'm spot on.
I don't think so. According to Lars, you want a combined actual timing at idle of about 30 degrees (initial plus vac. adv.).
Old Mar 19, 2014 | 11:12 PM
lars's Avatar
lars
Those numbers look just fine. The 36-degree target is total centrifugal advance plus initial - not total combined timing at idle. Your idle timing with vacuum at 32 is right on the mark; your initial timing looks good; and total combined timing at 52 is right on the mark, so your timing is no longer an issue - your total timing is likely right in the ballpark.
Now richen up that carb and you'll be in good shape.
Lars
