355 Still Leaking Need Some Help Here!!!!
You likely can look right at it and not see oil there. It can sit in one spot and idle and probably not leak a drop. Clean oil, fresh painted block, fan blowing it around, only leaks running higher RPM and gravity. Your down there staring at the oil pan, block, timing cover interface intently because that is where the oil is, you got your focus there. Real easy miss, can happen to anyone.
I don't know how many hours or miles it takes to seat in various types of rings on various types of honed surfaces. All I know is that it's best to get it done quickly for good results. The last 20% or so of seating takes quite a while 1000 to 2000 miles of normal driving. Running it hard will accelerate the process.
On my bikes I got max pressure on a compression test after three heat cycles and 1 to 2 hours of hard riding or racing. Then it would hold at that level for several hours before it slowly started to drop off.
Top ends would last maybe 70 to 75 hours the way I did it.
If done OEM style you got maybe 25 hours.
After a 10% drop I do another top end to maintain max HP out put.
On the engine I have now I took compression readings of all the cylinders after 500 miles. I'll use that as a benchmark to determine the health of the top end as time goes by.
Right now corrected to sea level pressure I have 205 psi average per cylinder with less than 6% variation between cylinders.
I'll just have to see how long that lasts. Probably will have a 406 in there long before it wears out.
Fired it up and ran it 25 miles....pulled it in the garage shut her down.
ILL BE DAMED IF THAT DIDNT FIX THE LEAK......DONE SON NOT EVEN A DROP. Such a relief after a month of chasing this leak.
Anyone need their pan and gasket replaced after doing this 4 times for nothing I'm pretty sure I got it down pat!! Haha
Thanks guys much appreciated help and advice y'all were dead on!
Glad mako nailed that one down.
Maybe you should keep all those blue rubber pan gaskets for when you really need one.
So I plugged the top bolt hole by the fuel pump and all was well for 3-4 days with no leaks thought everything was finally ok wrong again.
Took the car out for a 20mi run on Sunday stopped at the gas station and there were 5-6 drops of oil on the ground. Then got home and parked the car again 5-6 drops on the ground. The front of the pan at the bottom of the U is soaked. Passenger side top front of pan is soaked runs all the way to the bottom of the U. Oil splashing down the bottom of the pan as well as down the passenger side of pan. Oil is splashing as far back as the starter if not further. Oil is coming out of the breather on the passenger side (pretty sure breathers are supposed to suck air in not blow out oil).
Oil pressure guage at idle is fine once I get over 50mph its all over the place. If i give it more throttle oil pressure drops. Let off the gas and it then goes back up.
Here are some other issues I have as well:
Engine boggs down when giving it gas from a dead stop as if its starved for fuel
Hard to start now even with a HI Torque Mini Starter after first start.
Upon initial start up engine temp runs up to 250 stops and then drops back to 200 in less than 2 seconds.
Checked oil when cold before driving it was at the full line. Got home after driving and its now a 1/4 in high.
Totally confused back to the builder again......I am becoming so disgruntled with this car!
I have just about every symptom of blow by as far as I can tell without smoke coming out of the engine. I also put a differnt breather (K&N) on the car took it off becasue it was blowing all the K&N oil out of the breather.
So if this has to get rebuild where does it go from there 377? 383?
