Here are some pictures of my work and progress on modifying current H5001 and H5006 bulbs for use in the early C3 corvettes with the fiber optic light system.
Original or old bulbs look like the below picture. They have a glass nipple in the middle that sealed the bulb. This is what allowed light to pass onto the factory fiber optic system in the car.
Here is a Wagner bulb I disassembled to see how they went together and if it could be modified.
Using my Dremel tool with a 1/8" drill bit I drilled a hole in the back of each bulb.
I found a place online selling some unsheathed fiber optic in 1/8" I bought one foot to test with. Here is what it looks like. I also started to cut off small pieces to go into the headlight.
Here is the fiber test fit into the headlight
After I worked on getting the length of each piece right I went ahead and tested them to see if it would work. Here is a shot showing the light makes it through. I am using a 9V battery to test so it is not super bright.
I plan on using some silicone to hold them in place and eventually test fit in the car. I figure this post may help some folks figure an alternative to the pricey T3 bulbs that are made.
Can you let us know how far out you leave the piece of fiber in the modded headlight before gluing and how does it look in the fiber optic display panel when your done? How deep did you have to drill to get through the bulb housing?
Hi sig,
Very nice work!
Remember there was a little 'collar' that slipped over the original nipple and f.o. connector. It helped direct the light from the nipple to the f.o. cable.
You may want to include that. A short piece of 'shrink' tubing works well.
You don't shrink it in place, it's just 'trapped' by the connector.
Good Luck!
Regards,
Alan
Sig: Before you go too much further, you might want to power a modified lamp at full voltage to check filament life. From what I can see from your photos, it looks like the hole you drilled may have vented the atmosphere that filled the lamp to prevent premature failure of the filament(s). In any event, great idea - hope you can make it work!
Hi sig,
Very nice work!
Good Luck!
Regards,
Alan
Alan, I have thought about that. I was debating on if I wanted to use heat shrink, or possibly a rubber grommet. If you look at my test fit picture with both bulbs, you can see the rubber grommets in the middle on the desk.
I do not think there is any special atmosphere in these new halogen bulbs. During my dis-assembly, I have found that they are really constructed like a modern headlight. I do not have a picture, but they are similar to a 9006/9005 type bulb placed into a T3 housing. I broke the first one I drilled when I hit the glass bulb inside. With the fiber optic sealed into place with silicone, it should keep any dirt out as well.
If it is a bulb in a bulb you should be fine, your doing what I have been thinking about hope it works.
FWIW, vacuum hose works good too. It's cheap, plentiful and comes in a variety of sizes.
BTW, I appreciate your efforts in trying to keep our old cars functioning the way they were intended to as old technology is on its way out. Please keep us posted on how well this works.
Nice job! I used clear plastic tube from TAP Plastics on my H1/H4 bulbs. I remember cringing when drilling through the bulb connection plastic afraid I would destroy an expensive halogen bulb. I used clear poly tubing to keep the seal from fibre optic connection from plug to bulb. You should be careful trying to seal the lamp housing, I once wrecked an expensive set of Cibie lights using sealer, it out gassed into lamp reflector and wrecked my lamps. If you carefully look at the rubber boot, there is a vent passage from boot to outside air. Using a butyl rubber sealer like the right stuff might work but after wrecking a pair of $65 lamps way back when, I just leave the seals factory.
I also did a fibre optic connection to my LED tail lamps but the drivers side indicator output in the console is pretty weak otherwise everything went well there too.
I do not think there is any special atmosphere in these new halogen bulbs. During my dis-assembly, I have found that they are really constructed like a modern headlight. I do not have a picture, but they are similar to a 9006/9005 type bulb placed into a T3 housing. I broke the first one I drilled when I hit the glass bulb inside. With the fiber optic sealed into place with silicone, it should keep any dirt out as well.[/QUOTE]
Gotcha. One possible improvement would be to set the OEM fiber directly into the drilled hole to eliminate an additional FO interface. In doing searches on this topic, one common problem is getting the light to transfer across the junction. I know splices in broken cables can be pesky.
Gotcha. One possible improvement would be to set the OEM fiber directly into the drilled hole to eliminate an additional FO interface. In doing searches on this topic, one common problem is getting the light to transfer across the junction. I know splices in broken cables can be pesky.[/QUOTE]
That would be a good idea, but I've not had much luck at moving the fiber in my connector.
