Buy a set of 195 eliminators for $1550 and be done with it. You get what you pay for. The extra power they will make compared to anything else is the cheapest HP you will buy.
OK...NOW I've got you. Sorry...misinterpreted the whole thing from what you were thinking.
Now...we're talking a screamer huh?
Start with the Wallace Calculators to get an idea of cross sectional area needed for your RPM plans and cubes.
I witnessed a pump gas 327 a few years ago on the dyno with a set of 200cc heads that received some porting afterwards along with a solid flat tappet. He got it a little over 500 HP up around 6800-6900...and it hung on well to 7500. Cam was in the 260* range. Figure that's over 1.5 HP per cube...or similar to an 800 HP 540. Pretty good for a pump gas deal! Solid roller could have added to that. Or maybe even a good HR....they spin well on small blocks with good lifters.
Chad Spier is doing some neat stuff with SBC heads that turn some RPM. And his prices are decent also.
JIM
damn get dumber as i get older ya that's what i need to do. is the cross section the width at the push rod pinch and length of the port. Will the head manufacturer tell me the cross section on the head ?
This is why I'm considering profiler so i can have a better head then afr But when i find out the cost that will probably change any thought of it. lol.
If the 195's are good for 6500 rpm on a 350" what do you suppose there peak would be on a 331"? If the 210's are good from 3000 rpm to 7500 rpm on a 350" to a 400" do you think that they'd pull to 8000 rpm or 8200 rpm on a 331", or do you think valves might be to close to the cylinder walls and hinder flow, do the comp ported 195's pull peak power at high rpm with the larger valve diameter and the bore if the 331"? I've got a friend putting the 195's on a 302" should be interesting. Little mouse ddint sua what rpm he wanted peak hp to occur.
It seemed like the profilers flowed a little better.
AFR 195 @ .300 Int 201 Ex 166, .500 275/213, .600 280/218
Profiler 195 @ .300 Int 205 Ex 144, .500 277/194, .600 281/205
The Profiler do flow a little more on the intake side, weaker on the exhaust. I would rather have the higher I/E ratio to go with a little smaller exhaust side on the cam duration = less overlap especially if you end up with 250-260 duration @ .050. Then you need everything you can get to reduce whatever overlap you can. The profilers are a little cheaper.
The profiler info said something like 281 at .500" or something like that. but it was posted by spier. I get the i/e ratio though. Didn't think about it.
Some of the bigger 23 heads can show just as good flow numbers compared to some raised changed valve angle head, which head would you want.
Myself, I like to keep it old school 23 degree. It's just seeing what you can get out of an almost 60 year old design that gives me satisfaction. It's like making big power out of Harleys. Make a tractor fly. It's more fun for me.
It's getting easy to get LS motors and easy to make power with them. just not the same. If I was building a daily driver for my wife, maybe.
If you like Harleys but its expensive to get one to run when the factory could make one run at least decent no excuse for it.
On a different subject got my new light weight rods. Beam width is scary to look at going to call flatlander racing send them back for something else. go with a 6.00 length longer stroke. have to shop at eagle for a 3.250 don't really like that and it causes to many problems on parts match up.
Scat makes a 3.335 stroke crank. It is lightweight and has the 2.00 rod journal 'Lighter than 2.10".
This gives you a super lightweight rotating assembly with good quench, a 5 CC mini domed race forged piston and 4340 H beam rods with ARP bolts and 12.6 to 1 compression with AFR 195 heads. Should stay together @ 8000 RPM and be able to cam it big enough to run pump gas and pull the RPM your looking for.
This cam gets you about 8.5 to 1 DCR, the right operating range, and adequate lift for the heads. http://www.compcams.com/Company/CC/c...?csid=222&sb=2
The AFR heads come with lightweight valves. Upgrade springs to the 8019 and ask about titanium retainers.
I think im just panicking after comparing them to my standard weight rods. These are 503 in weight probably same steel company in china making all these rods just different people in the states doing the final work. Callies 525 gram lightweight rod they claim 650 hp at 7500 rpm rating same 3/8 bolts. Going to buy two carbs for my offy cross ram clone manifold give it a whirl.
hey I have to do this with pump gas I'm not that big a big a believer in DCR to rely on it.
After talking to people on flat tappit cams would not buy one without a pro 55 cam core.
