Oil Pressure High
Old Mar 28, 2014 | 07:19 AM
Red Hot 71's Avatar
Red Hot 71
Default Oil Pressure High
Bought a 71 coupe (350/270) back in June of 2013 & oil pressure has read 70 psi from day one. I know that is not right, so do I just change the sending unit or do I concentrate on the gauge? When the motor is not running it drops to 0, so the gauge does not appear to be stuck. The guy I bought it from said the motor was recently re-built. Runs great & I am not having engine problems, but I want the gauge to tell me the truth.
Old Mar 28, 2014 | 07:42 AM
Indiancreek's Avatar
Indiancreek
Pick up a mechanical gauge and check it. If it shows staying at 70 psi warm at idle something is odd, unless someone has messed with the oil pump. What weight oil are you running?
Old Mar 28, 2014 | 07:58 AM
Red Hot 71's Avatar
Red Hot 71
10W-30 Halvoline.
Old Mar 28, 2014 | 08:49 AM
Una4dbl55's Avatar
Una4dbl55
It's most likely a high volume oil pump in there,
I have an 80 that does the same
Old Mar 28, 2014 | 10:17 AM
Indiancreek
The high volume pump won't get that done. Two things control the pressure, The bearing clearances and the max pressure valve. With that good of pressure, it should mean you have good bearing clearances. That's why I'd verify the pressure with an external mechanical gauge. Let's see if the number you're getting is correct first. May be much of nothing.
It's like a garden hose, you can run volume at just normal house pressure, Until you pinch the hose you don't get extra pressure. The better the pinch the higher the pressure. Same as the oil going through your bearing system.
The 3.8 and 4.1 Buick V6 oil pump kit comes with several springs to install in the pump to regulate max pressure so you can adjust the point where the over pressure bleeds off.
Old Mar 28, 2014 | 10:24 AM
qwank's Avatar
qwank
there's a difference between a high volume pump, and a high pressure pump
Old Mar 28, 2014 | 10:48 AM
7T1vette's Avatar
7T1vette
Either the sender unit is defective (causing a 'false' high reading) or the pump has been changed in some manner (aftermarket pump or changed pressure regulator spring). If you cross-check with another gauge that the pressure reading is correct, the only negative issues that elevated oil pressure will cause are:1) some small loss of fuel mileage, due to more power being required to generate that much oil pressure all of the time; 2) more engine heat created, due to that increase in power usage; and 3) harder working of the pump. None of those reasons would justify a 'special effort' being made to change/alter the pump immediately.
Wait till you need to drop the oil pan for some other reason....THEN work on the oil pressure issue.
Old Mar 28, 2014 | 11:28 AM
tsw71's Avatar
tsw71
FYI, 71 is a mechanical gauge. No Sending unit.
Old Mar 28, 2014 | 01:15 PM
billla's Avatar
billla
St. Jude Donor '14
Pressure is determined by the bypass spring...but an HV pump can certainly cause the engine to be in near-continuous bypass regardless of the spring.
The Melling Select performance pumps typically come with both springs, and people seem to be reluctant to drive out the pin and replace the spring if the HP one is in there. It's quick and easy to do. The combination of HV and HP means the pump is in continuous bypass.
I'd agree that step one is testing using another gauge - but I suspect that it's simply a pump with an HP spring.
Old Mar 28, 2014 | 02:51 PM
zwede's Avatar
zwede
A Corvette should have the high pressure spring. Standard spring maxes out around 55PSI or so. High pressure spring 70 PSI.
In this case I think someone installed a high volume pump. Will probably not hurt anything, but if it were my car, I'd drop the pan and install a standard pump (w/ high pressure spring) like the engine was designed for.
With 10W-30 oil and a fresh engine oil pressure at idle will be in the 30-35 PSI range. At higher revs it should go to 70 PSI.
Old Mar 29, 2014 | 03:26 AM
terrys6t8roadster's Avatar
terrys6t8roadster
have hi volumn pump in mine, 70 psi. T
To Oil Pressure High
