radiator sealant
Old Mar 28, 2014 | 09:59 AM
donaldbly's Avatar
donaldbly
Default radiator sealant
Can radiator sealant be added to over flow tank instead of radiator?
Old Mar 28, 2014 | 10:38 AM
my 76 ray's Avatar
my 76 ray
Just my opinion but I wouldn't add it to either unless it was a dire emergency.
Old Mar 28, 2014 | 10:43 AM
7T1vette's Avatar
7T1vette
The overflow tank isn't under pressure, so the leak sealant won't really work like it should. You would be much better off to remove the overflow tank and have it repaired. Any radiator shop (car, truck) can do that job easily and leak test it afterwards for not very much cost.
Just get it fixed correctly.
Old Mar 28, 2014 | 11:33 AM
REELAV8R's Avatar
REELAV8R
Yes. When the engine warms up the water will expand and some will be displaced to the overflow tank. Then when it cools after shut down it will be pulled back into the radiator along with the stop leak you added.
To radiator sealant
