Basic Tach Face Replacement?
Old Apr 1, 2014 | 07:40 PM
Bel's Avatar
Bel
Default Basic Tach Face Replacement?
I have a 70 Vette that I want to simply replace the Mechanical Tach Face. Everything I've read talks about pulling the Tach out, which appears overkill . . . to me. Isn't it simply removing the driver side dash panel; exposing the Tach lens; removing the Lens; and then removing the Tach needle and then two screws to remove and replace the face; and then replace the needle? Any help, criticism, etc. is appreciated before I dig in. https://www.corvetteforum.com/forums...es/cheers2.gif
Old Apr 1, 2014 | 07:55 PM
Alan 71's Avatar
Alan 71
Hi Bel,
There's not really a way to remove the dash pad and leave the gauges in place… the gauges come out with the pad and must be released from the back side of the pad to even gain access to the lens.
Regards,
Alan
In this picture you can see one of the small hex headed screws on the speedometer that holds it in place. There are 3 of these on the tachometer housing that must be removed to release the gauge from the dash pad in order to have access to the lens.
Old Apr 1, 2014 | 07:58 PM
Super6's Avatar
Super6
The tach face is too big to come out the front side of the dash, even with the lens out. Between the lens and the tach is a "barrel" that has a smaller ID than the OD of the tach face.
Old Apr 1, 2014 | 08:13 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Like the two post above stated, the driver side pad must be removed, then the "Can" removed from the dash.
Once you gain access to the face and needle it is pretty simple. You turn the needle counter clock wise while pulling upward and it will come off. To put the needle back on you start with it at 100 mph and gently push inward while you turn it back to zero. (friction fit) It may take you a couple of times to get it right.. and pay attention to exactly where the needle is at before you remove it so you can put it back in the same place.
If you need help pulling the left pad go read this.
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
Willcox
Old Apr 1, 2014 | 08:27 PM
TeaEye's Avatar
TeaEye
Bel,
It's gonna be a big job. The process is simple, but access is the killer.
I just did it!
Suggest you review willcox's thread! Most helpful.
http://willcoxcorvette.com/instructi...77_secured.pdf
Once accessible, you will be removing three screws to pull the TAC out. Don't forget about #3 screw. It's hidden pretty well. They are 1/4 inch and nut driver works great.
The picture is of a TAC for 75 on... However, the three screws were the same for my 74 and should be for your TAC as well.
Pull back the TAC. Take to your clean work area.
Then you will pull off the needle gently. Next, The two screws on the face. USE the largest blade that fits the entire screw head securely with no play. If you use a baby screw driver, may not get enough bite and distort the head.
Other things:
Before you try to pull the dash out, Make sure the two cables (speedo and TAC) are disconnected or you will break the blue plastic shrouds! Some people disconnect the cables in the engine area and trans and push them into the dash area. Done it both ways! Same same.
Light switch is tough, mark the two vacuum lines so you get them in the right order. Don't forget them on the reinstall. Light switch wires are never long enough!
Before you start pulling things apart, take a few pics if possible or make a few routing notes.
Before you secure the dash, check the bulbs make sure they all work.
Most of all take your time. When you get frustrated. Stop and come back to it.
Hope this helps....keep asking questions.
Old Apr 2, 2014 | 07:38 PM
Bel's Avatar
Bel
Thank you all. This was certainly an eye opener from what I envisioned. The information offered makes the job pretty clear. I've read a lot of articles not near as clear, and the virtual reality walk through you all have offered should certainly "minimize" any frustration on my part.
P.S. If I plan on replacing the top dash pad, I guess this would be a good time as well, or doesn't it matter if I do this later?
Again, very much appreciated to all. Bel
Old Apr 3, 2014 | 10:43 AM
Alan 71's Avatar
Alan 71
Hi Bel,
Now would be the time to replace the upper pad.
It too is not a trouble free job because the pad needs to be 'humped' slightly in it's middle to get it to slip into position. Try to do it on a warm day when the pad has been sitting in the sun for a while.
Also, the detail and fit of the new pads isn't always as good as the originals.
Regards,
Alan
Old Apr 3, 2014 | 07:21 PM
Bel's Avatar
Bel
Thanks Alan. Access to Corvette Forum and you guys have answered in much greater detail more to my questions than I've been able to sift through the Internet and most parts catalogues over many months of searching. I'm retiring next Spring and have this 1970 Vette hungry for attention, both fix and play. I'll be working on the Dash this Spring, and then enjoy her over the summer. You guys are the best. Much appreciated. Bel
To Basic Tach Face Replacement?
