75 vett
Old Apr 3, 2014 | 01:47 PM
scrappy ron's Avatar
scrappy ron
3rd Gear
Default 75 vett
I have been putting a 350 in this vet I am working from boxes of parts and I got all my belts on with the stock bracket and the alternator belt hits the power steering pump what should I do?
Old Apr 3, 2014 | 02:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is the power steering pump mounted correctly? Is the alternator mounted correctly? Are you sure the alternator pulley is the correct one? Is the belt routed correctly?
Can you post a pic?
Old Apr 3, 2014 | 06:42 PM
scrappy ron
3rd Gear
Can you post a pic?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Apr 3, 2014 | 07:21 PM
Cavu2u's Avatar
Cavu2u
Default Pump position
There's very little clearence in the same place on mine too. Your mounts look correct. Perhaps the removal and a slight bend of the pump bracket may give you the clearence needed.
Old Apr 3, 2014 | 11:33 PM
MidShark's Avatar
MidShark
I can't see for sure, but it looks like your alternator is about at the end of it's travel on the adjusting brace. i would say the belt is a little too long. Get the correct belt that's called out for it, or one that's an inch or two shorter than what you've got.
Old Apr 4, 2014 | 01:31 AM
Bromleys Corvettes's Avatar
Bromleys Corvettes
Thats what it looks like to me as well. Get the next size down on belt you may need to take valve cover off to get belt on and tighten it then put valve cover back on
Old Apr 4, 2014 | 04:29 AM
7T1vette's Avatar
7T1vette
The other alternative would be to place a thick flat-washer in appropriate mounting locations on the alternator bolts/studs, so that it is moved forward just a bit.
As mentioned above, is it possible that a lower support brace has been left out of the P/S pump build?
Old Apr 4, 2014 | 06:40 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
This is a better solution as opposed to bending brackets.
Old Apr 4, 2014 | 10:43 AM
qwank's Avatar
qwank
once you start bending brackets you get other alignment issues.
Old Apr 4, 2014 | 11:05 AM
Cavu2u's Avatar
Cavu2u
Old Apr 4, 2014 | 11:38 AM
TeaEye's Avatar
TeaEye
Scrappy,
Take a look at my photo. Notice I stuck a few washers to move the alt bracket out a tad. I also used the stock FAT washer under the belt adjusting bracket. Also looking at your alt bracket, looks a little different them mine. BTW: Mine is from a 1975 parts car: cast iron.
The way I decided how many washers to install was by the interference that you are trying to fix and both pulleys MUST be even, not cocked. Can't tell by your photos.
Can only post one picture per post. So may be back with another picture.
Old Apr 4, 2014 | 11:51 AM
TeaEye's Avatar
TeaEye
Default Alternator & PS Pump Clearance
One more picture. Showing more of the alternator bracket and the clearance between the belt and PS pump.
Old Apr 4, 2014 | 12:39 PM
scrappy ron
3rd Gear
thanks guys for all the help I am working on it today and I noticed the power stearing brakent is bent so I am going to try and bend it back and still might stace out the alt brakest too
Old Apr 4, 2014 | 05:53 PM
Cavu2u's Avatar
Cavu2u
Default Alright!
Success!
To 75 vett
