ride height question
Old Apr 9, 2014 | 02:35 PM
Belgian1979vette's Avatar
Belgian1979vette
Default ride height question
I was tweaking my 79's suspension and was trying to correct something that has bothered me a long time.
Car has undergone a full restoration, so every suspension bushing is new. Springs are new etc.
Left rear sits lower about 1" at the wheel well and the left front sits about 1/2" lower as well. I made all possible checks already : location of the springs in the pockets etc.
Chassis is not bent or hit. This was verified during the restoration.
When I jack up the frame behind the left door (in front of the wheel) enough to get the frame at the rear left and right sitting at the same height, the wheel well heights in both front and rear are the same. This indicates that body shimming and frame is correct but something seems to be wrong with the springs.
It seems that somehow the springs on the left side are too weak.
I also tried to adjust the rear spring bolts on the left to get the car more even but to no avail.
This makes me crazy.
Is there any way this can be tweaked ?
Old Apr 9, 2014 | 04:04 PM
hugie82's Avatar
hugie82
The rear is adjustable so I would get that up to level height first then see how far off the front is. The springs are easy to knock out of the pocket when installing. I messed up on mine and had to go back. It has to be tucked in the notch good or it will affect the height! Also did you sit the car on the ground before tightening the bushings. If you're using rubber it will make a big difference!
Old Apr 9, 2014 | 06:58 PM
Belgian1979vette
Yes, bushings were tightened on the ground.
Springs are seated correctly.
I already tried tightening the bolt of the left rear but it didn't help. This makes the car go up both on the left and right rear.
I'm thinking of putting in a spacer in the left front to raise it a little. That will also make the right rear go down if I'm not mistaken.
I have seen many threads about this issue. I wonder what is going on with these cars in that respect.
Old Apr 9, 2014 | 11:24 PM
cagotzmann's Avatar
cagotzmann
Did you make any measurements from the frame to the ground and compare all around. My 78 measures very close along the frame side to side, but from the body to ground left side is low. This is due to poor body mounts. I am in the process to replace my body mounts. If yours are new then if the frame measures ok then check the body mounts.
Old Apr 10, 2014 | 12:15 AM
rogman16's Avatar
rogman16
Kind of in the same boat, but I have fiberglass springs front and rear... I am going to wait until I can drive around the block after adjustments are made... Tightening and loosing spring bolts do absolutely nothing if the car isn't moved to reset ride height...
Anxious to see what you find out!!!
Rogman
Old Apr 10, 2014 | 12:45 AM
gkull's Avatar
gkull
If the front springs are mounted correctly the only adjustment is on the opposite corner of the rear spring. Driving will settle out new springs then readjust.
you also need to put your weight in the drivers seat for height and correct alignment
Old Apr 10, 2014 | 02:43 AM
Belgian1979vette
Rogman
I drove around after fiddling with the rear spring bolts but it did nothing to the lean on one side.
This seems to have been around a long time with these cars and nobody ever came up with a solution.
Old Apr 10, 2014 | 09:50 AM
qwank's Avatar
qwank
where are you measuring? measure from the frame right behind the tire to the ground on both sides in the front. my right side originally looked lower and measured lower from ground to fender, but from ground to frame was exactly the same on both sides.
It turns out the bolts that support the nose bracket on the right side were loose. I jacked up the nose to the correct height and tightened the olts and everything was looking level again.
Old Apr 14, 2014 | 05:21 PM
Belgian1979vette
I searched for my old front coils and noticed that one was a lot higher than the other. The shorter one didn't seem to be cut, so I assume that the factory installed different length springs or something.
The 550 lbs springs I have in there now are equal lengt. I ordered a 1/2" spacer with an order I was making. Will see if that solves anything.
Old Apr 14, 2014 | 06:00 PM
redvetracr's Avatar
redvetracr
not likely
Old Apr 15, 2014 | 10:06 AM
7T1vette's Avatar
7T1vette
I'm wondering if the left-rear body mount is solid (or not). The rear suspension must leverage against it and the front pivot mount on the trailing arm for the system to work as designed. If that body mount is weak/damaged, that may be the cause of your 'droopy' left side.
Old Apr 15, 2014 | 10:40 AM
Belgian1979vette
body mounts are all solid and checked during body off restoration.
Old Jun 13, 2014 | 03:48 AM
77TSi-meez's Avatar
77TSi-meez
[QUOTE=Belgian1979vette;1586661537]body mounts are all solid and checked during body off restoration.[did u ever find a fix? For your height problem? I'm having the issues.
Old Jun 13, 2014 | 04:35 AM
terrys6t8roadster's Avatar
terrys6t8roadster
[QUOTE=77TSi-meez;1587122731]
A friend of mine had that problem after installing a new spring. I told him to remove spring, flip flop end for end reinstall. Problem gone. T
Old Jun 14, 2014 | 03:12 AM
77TSi-meez's Avatar
77TSi-meez
[QUOTE=terrys6t8roadster;1587122771]
Good to know.
Thx Terry
Old Jun 14, 2014 | 08:03 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You should always start by verifying your that suspension's front Z and rear D geometry are good to go and that the frame is true and square first. Then, only after that checks out should you move to secondary measurements such as trim and body heights.
To ride height question
