Power door lock relay
AND REMEMBER...just because you are getting 12 volts...does not mean that it will work....because if the wire has 20 stands in it...and 18 of them are broken...it will still show 12 volts when checked...but when the amp draw is required to operate the actuator...it can fail due to 2 strands may not be enough to supply the amps to make the actuator move.
The actuator work as such. The actuator does NOT need to be grounded...because the power door lock switchs the power and ground on the two terminals via the switches....and YES..you need to have both switches in working order to get this system to function..
DUB
And, while you are in there, go to the effort of foam wrapping or otherwise insulating both the door lock and door opening rods. This, along with adjusting the door window anti- rattle pads on each door will greatly improve the sound of your doors closing. Use spray-lithium on all the moving sliders and gears while you are in there. As well.
Dave
Make sure both have power. You will notice one has more wires going to it then the other.
Jim
Dave
Also, lubing everything in the mechanisms for the first time since the car was built and getting the doors to quietly close was a double bonus.
Good luck!
Please keep in mind I repair Corvettes and this issue is VERY COMMON.
ALSO...what occurs is that when the door lock actuators begin going bad...they begin to bind up and be hard to move by hand...EVEN THOUGH they work electrically...manually they are hard to move.
IF..your door lock actuators are hard to move up and down by hand (even with the linkage disconnected at the latch)....but yet they work electrically...I would replace them.
I have gone through a dozen NEW AC Delco actuators until I found 2 good ones that are VERY EASY to move the plunger in the actuator. I feel the actuator plunger and I want it to take little to no effort for me to go up and down with the plunger...and the REASON IS....when you are going to UNLOCK your door....your door key has to move this plunger....BUT...and here is the "KICKER"...your door is SMC and I have had to repair MANY doors due to the door lock cylinder had spun and broke the SMC...so NOW...the door lock cylinder is useless....and this was caused by a binding actuator.
I have found that the DORMAN actuators are the best..because I can rock my hand back and forth and the plunger moves freely.
What I also do...which I would advise you to do..because if you do not do this ( obviously ..your choice) and you break your SMC....you WILL wish you had. I clean/lube the latch mechanism...and when I have installed the actuator and linkage...I remove the linkage from the latch and test the door key and feel it and it will lock/unlock the door freely...then I connect the linkage from the actuator assembly and test it again. IF EVERYTHING is GOOD...the effort to lock and unlock the door is well within acceptable torque vales and I finish the job. SO...this is why it is IMPORTANT that the actuator...EVEN IF NEW....is easy to manually move. If you feel like you are beginning to grit you teeth waiting on the door lock to move and unlock the door...that is too much effort and you may want to re-investigate it again.
ALSO...if this condition has been going on for a long time...I have had to replace the door lock cylinders due to the metal pawl that clips on the backside of the door lock cylinder actually eats a groove in the pot metal cylinder end...which thus changes the turning radius and sometimes will not work at all or dis-arm the alarm system.
The black plastic water diverter shields are IMPORTANT...Correctly sealed and installed will aid in other issues down the road...water/dust/dirt related.
DUB
DUB
Dave
I could be the other switch or one of the wires. The switches work in series.
Check the tan and gray coming from the driver side actuator. They go from the driver side switch to the driver side actuator, then from the driver side actuator to the passenger side actuator. As you click the switch you should get the same thing on the same color wires at both actuators. If so the these wires are good.
The driver side switch has a black that is the ground and runs to the passenger side switch. The passenger side switch black grounds on the passenger side...it acts as the ground for both. Makes sure the ground on the passenger side is good.
DUB
