'72, storage compartment, center tray
Old Apr 22, 2014 | 05:37 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default '72, storage compartment, center tray
The AIM sort of looks to show that the cardboard center compartment tray is permanently fastened to the car by sandwiching it between the three-door plastic frame and the car. It this correct?
It would appear some bending is required on the repop cardboard tray to accomplish this.
Thanks,
Dou
Old Apr 22, 2014 | 07:02 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
There should be some metal clips that hold it in place on the compartment tray they are s shaped and about 1/4 " wide and slide over the edge of the cardboard tray. You shouldn't have to bend it.
Old Apr 22, 2014 | 08:58 PM
kjbuster1's Avatar
kjbuster1
Default Tray
Thanks,
Dou
I just had mine out as I carpeted the lids. With the lids off the " tray "remains in place. It can be lifted out then. I had to patch mine on the battery side. It stays in place by fitting into the bottom of the lid assembly. Then there are screws from the lid frame into it. You'll have to disconnect the box light to take the tray out.
Old Apr 23, 2014 | 08:47 AM
Alan 71's Avatar
Alan 71
Hi AZ,
As sug and kjb posted:
The liner is held in place along it's rear edge by the 3 screws for the compartment lid that pass through the liner.
In addition there is generally 1 small clip about mid-way along the liner's sides.
Regards,
Alan
Screw holes (note 1 screw was very crooked on this liner.)
Mark left on the liner surface from the clip.
Old Apr 23, 2014 | 09:51 AM
AZDoug's Avatar
AZDoug
I found one metal clip up inside the old plastic surround.
i assumed it had something to do with the wires to the courtesy light, being as I only found one.
Is this clip an available part?
Thanks,
Doug
Old Apr 23, 2014 | 01:48 PM
Alan 71's Avatar
Alan 71
Hi Doug,
I've not seen the clips offered anywhere.
Since the liner actually sits on the fiberglass underbody once it's installed I think you can successfully install it with just one clip.
As far as I can see the clips aren't even shown in the 71 AIM.
Regards,
Alan
Old Apr 23, 2014 | 08:25 PM
AZDoug's Avatar
AZDoug
FWIW, I see what appear to be three professionally drilled holes and screw head recesses on the left side of the large plastic surround to hold the side of the tray (using typical screw clips on the tray), with the clip on the right side. i see no scuff evidence of a clip on the left side of the old surround, like is evident on the right side.
Not sure if that was dealer fix, or PO fix, or what.
Doug
Old Apr 23, 2014 | 10:37 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Just rebuilt my 72 door set two weeks ago. Mine had one S clip per side and three screws at the rear. I went with speed nuts and flush screws all around in the recessed holes. The S clips appear to be the same as the ones used for the seat cushion bottoms. If you go with the screws remember the need to be absolutely flush or they'll bind on the door frame.
I don't see in the AIM where retainers are specified either.
To '72, storage compartment, center tray
