Hey guys sorry if this is in the wrong place. I did look for a power steering thread. I replaced my power steering system, AC Delco remanufacutred power steering pump, control valve, cylinder and all new lines. I turned the wheels lock to lock 20 plus times and refiled the fluid until It didnt move any more.
My question is do i need to use the bleeder on the bottom of the control valve for getting air out. Should I start it and then open that valve please let me know I really don't want to turn my fluid to foam when I first start it back up. Should I start it then open that valve?
It self-bleeds. Turning the wheel with the engine off purges most air from the system. Once you start the car, turn the wheel lock-to-lock a couple more times and all the air should be out. Recheck the level after you've done this as it will probably be a wee bit low. What air -mostly bubbles- may be left in the system following the engine off and engine on purging is inconsequential and will quickly purge itself.
And do not over-fill the pump, you'll make a mess.
And don't forget to balance the valve. New or rebuilt valves should always be centered after installation.
