82 xfire engine. Was running rich and boggy, Pulled codes and got 33,34 and replaced MAP sensor engine light kept coming on. So then pulled a 15 code. So I replaced coolant sensor. Then 34 came back , so looking around I noticed whoever had it did a messy job on the intake. pulled replaced all gaskets , even put in 195* thermostat. So got the timing on TDC set at 6*BTDC (I even had the EST wire unplugged) ran like a champ !!! plugged up EST wire it went up about 12-16* in advance. So set all back again. And same thing. Still ran like poop. So once more ,well this time I did tune up , plugs ,wires,cap,button. Went to turn it over and it will not crank. I have spark, I have injectors coming on and spraying while cranking,I have power on fuel pump fuse as cranking, fuse on ecm has power, However there is NO POWER going to "CRANK" fuse. What the heck is this, and why doesn't it have power so before I start taking the fuse panel out I thought I would post and see if anyone had any possible answers or suggestions. Thanks
did all this happen at all of a sudden ,had it it been running fine .everything goes bad after you plug the est wire back in? check balancer.it may have changed.
yes I have check balancer each time I set it it runs fine until I plug up est wire . then it runs like crap,hardly even idles. But now it wont even start est plugged up or not.
i did get power on that crank fuse only while cranking,which makes sense. Its kinda got me stumped. I have ALDL hooked up to it now I dont have sensor readings , If the ecm was shot would it still submit data?
I'm assuming we're talking about an 82 CFI right??? You're saying when you plug the brown wire to the distributor the motor runs ruff and dies? I would think your problem is in the distributor since the advance and dwell modules may have bad contact or just went bad? I guess the first step would be check for spark and work back.
Yes I did check for spark. The battery does seem a little weak , would that make the spark weak also ? Yes? I will charge . Injectors are spraying as im trying to crank it. How can I test the module. seems like it is missing that something to get it fire up
You can't really test it. When you changed the cap did you put the ground wire back on the coil? Are the wires on the driver side of the distributor plug in good and tight? Did you maybe pinch or break one of the wires going in on the passenger lower side of the distributor?
Don't pull the fuse panel. Try changing the fuse(s). I've heard this has solved problems even when the fuse(s) looked good.
I did visually inspect wiring and plug wire. I will do it again this afternoon.? The ground wire on the cap? I replaced all of the guts on cap . Wouldnt no ground create a no spark?
There is a cooper tab on it with a wire. sits on the coil and grounds to the cap where those wires plug in on the driver side. No, it will run rough with out it. I chased a similar problem a few years ago when I had a mechanic change the coil. I eventually found the wire and tab sitting on the bell hosing so the car will run without it for a bit until you fry the coil.
The wire is easy to miss, it will fall out when you take the coil out.
if you had spark and lost it after the cap/rotor/plugs/wires, I think I would be reinspecting your installation of these parts, especially the installation of the coil and check the ignition module while your in there. you might have disturbed something
I think ive looked at that like 8 x now I'm like??? So I did check the module ,wiring and reset the timing once again. I pulled out #7 Plug and gas came pouring out. Considering it isnt firing wouldn't gas seep thru to the piston?
I had it running strong , plugged up est wire ,ran like crap , stopped it reset timing and cant get it to crank to save my life
yikes! if gas poured out and you cranked, you have a bent rod now! (I hope not)
I am suspecting your valve timing. Can you confirm that #1 Top
Dead Center (TDC) compression stroke matches the distributor at #1 firing position (mechanically?)
HMMM.. so when the est wire get plugged up the ecm tells the engine to advce the timing .correct? So if the bushing on the balancer is bad it can advance to Much right? Is the bushing bad if you are tdc and trying to achive the same result each time and the timing marks fluctuate from 8*btdc -4*atdc???
