Carb Question
Old May 10, 2014 | 10:18 PM
Vet76te's Avatar
Vet76te
Default Carb Question
I recently acquired my 71. She's an all original 270hp automatic with the numbers matching Q-Jet. She starts up and runs GREAT.
However, if I stomp down on it...the car spits, coughs and bogs down. It slowly picks up and reumes running well. After this, when I top and shut her down...the gas smell is terrible. No signs of leaking....just a terrible gas smell.
As long as I don't try to stomp down on the accelerator hard it does fine. It cruises at 75 to 80 with no problem. I just can't kick it down hard. I assume while it's running on the 2 barrels she's fine.
Any ideas or suggestions?
Old May 10, 2014 | 11:04 PM
Vet76te's Avatar
Vet76te
I have not replaced the spark plugs yet. Coukd hat be the problem
Old May 11, 2014 | 07:12 AM
Jartanyon's Avatar
Jartanyon
I would definitely always change spark plugs on a newly acquired car. It could also be the secondaries spring tension needs to be adjusted (too loose). I am sure Lars will chime in shortly.
Old May 11, 2014 | 09:16 AM
Vet76te's Avatar
Vet76te
Thanks Jartanyon. My car doesn't miss fire, it idles well and even runs very good...as long as I don't "punch it". So I never thought about replacing the spark plugs.
But I started wondering if maybe the Q-Jet was opening up and dumping so much fuel in that the old plugs couldn't burn it, (thus bogging it down for a moment).
I'll try replacing them.
Old May 11, 2014 | 09:26 AM
jnb5101's Avatar
jnb5101
First, do a general tune-up with new points, condenser, plugs and wires. Second, get ready to rebuild the carb. The accelerator pump is shot-get one that is ethanol resistant.
Old May 11, 2014 | 12:26 PM
scottyp99's Avatar
scottyp99
I don't know, man. I would think that if the accelerator pump was bad, you'd have problems at part-throttle, too. If you give it 1/2 throttle with no accelerator pump, it's going to puke and stumble a bit. From the limited info, it sounds more like the secondaries are mis-adjusted. A general tune-up and carb rebuild is still a great idea, though.
Scott
Old May 11, 2014 | 12:28 PM
7T1vette's Avatar
7T1vette
Most likely problems are: (in priority order)
1. The seal at the bottom of the accelerator pump (in the carb) is worn out or damaged by ethanol in your gas. You can replace just that by removing the top cover of the carb {and the other stuff required to get the top cover off}.
2. Your ignition timing is excessively retarded. Check timing with a timing light. Also determine if the vacuum advance can (on the distributor) and the mechanical advance system in the distributor are working properly. [this can be determined with your timing light by the action of the timing mark when you alter throttle position]
3. Ignition coil or condenser problems providing a weak spark.
Old May 11, 2014 | 03:46 PM
lars's Avatar
lars
The following is a list of just a few of the issues that will cause and/or contribute to the problems you describe:
  • Incorrect plug gap
  • Bad plug wires
  • Incorrect dwell
  • Bad points
  • Retarded timing
  • Vacuum advance control unit stuck
  • Sticking centrifugal advance
  • Loose secondary airvalve spring tension
  • Sticking secondary airvalves
  • Ruptured choke pulloff
  • Misadjusted or missing secondary airvalve rod
  • Low float level
  • Incorrect float
  • Secondary fuel transfer tubes fallen out of airhorn - laying in float bowl
  • Low float level
  • Incorrect secondary rod hanger height
  • Incorrect secondary rods
  • Incorrect primary jetting & rods
  • Commercially rebuilt carb with incorrect air bleeds installed
  • Accelerator pump rod installed in wrong hole in pump lever
  • Bad accel pump
  • Choke misadjusted - not opening fully
  • Secondary lockout lever not fully retracting
Lars
Old May 11, 2014 | 07:40 PM
jnb5101's Avatar
jnb5101
Only 23 choices? How about two from column A and two from column B?
Old May 11, 2014 | 08:28 PM
lars's Avatar
lars
That's the point. It's absolutely, positively impossible to troubleshoot drivability issues as described via Forum posts and e-mails. I've listed 23 items that all can cause, or contribute to, the issues noted. Most likely, it's not one of the issues listed - it's likely a combination of several of those issues combined with an issue that's not even on the list that nobody could imagine (I had a guy try to install a Q-Jet backwards once, and he couldn't figure out his throttle linkage. I spent hours with him on e-mails and phone calls until I realized he actually had the carb backwards. I'm not kidding). It's probably not an accel pump issue, or the car would die as he tried pulling out from a standing stop. But maybe it is.
Bottom line and fix:
The car needs to be given a complete proper ignition system setup, and then the carb needs to be torn down, inspected, cleaned up, corrected, set up, and tuned.
Lars
Old May 11, 2014 | 09:04 PM
Vet76te's Avatar
Vet76te
Lars
Hi Lars,
Do you do carb work for the public, (forum members)?
If so...would you be interested in working on mine?
What is the process of getting it to you?
What is an average turn around time?
What would an "estimated" rebuild / setup cost run?
Old May 11, 2014 | 10:47 PM
lars's Avatar
lars
Just drop me an e-mail with a request for my Services Info Sheet. You might also ask me for my timing papers: "90% of all carb problems are ignition problems." Set up your timing and ignition curve before ever touching the carb, since you cannot compensate for timing issues with carb tuning. Once timing is known to be good, you can tackle the carb, and I'll be glad to set it up for you.
Lars
V8FastCars@msn.com
Old May 11, 2014 | 10:55 PM
Vet76te's Avatar
Vet76te
Lars
V8FastCars@msn.com
Thanks Lars,
Email sent.
DT
Old May 11, 2014 | 11:53 PM
REELAV8R's Avatar
REELAV8R
  • Bad plug wires
  • Incorrect dwell
  • Bad points
  • Retarded timing
  • Low float level
  • Incorrect float
  • Low float level
  • Bad accel pump
Lars
You should just add the other 50 some potential items, make it a sticky and required reading prior to carb questions.
Old May 12, 2014 | 11:02 AM
7T1vette's Avatar
7T1vette
Testing for accelerator pump operation is very easy: Remove air cleaner housing/filter; hold choke flap open (over primary venturi) and look down into the primaries; manually actuate the carb throttle linkage to full-open position quickly. If you see a strong squirt of fuel being shot into each of the two primary venturi, the accelerator pump is fine. If you see very weak streams...or none at all...the pump seal probably needs to be replaced.
But, getting the entire carb reviewed, repaired and rebuilt by Lars is a good way to insure its performance.
Old May 12, 2014 | 11:17 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
He fixed a bunch of problems I had by rebuilding and setting up my carb. Very satisfied with the results! I highly recommend sending it to him AFTER you give your car a proper tune-up. That was he knows what your engine's condition is and can better judge what settings your carb needs.
To Carb Question
