Differential in a bind
Old May 13, 2014 | 01:33 PM
croaker's Avatar
croaker
Default Differential in a bind
My rear Diff. seems to be in a hell of a bind up and to the pass. side.I wedged a wood wedge at the top but I still had to drive the bolts out with a punch and hammer? All input welcomed.
Old May 13, 2014 | 02:07 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Are you talking about the differential frame mounts?
Old May 13, 2014 | 02:15 PM
croaker's Avatar
croaker
The bracket where the snubber is while I was trying to get it unbolted looked like once I got the bolts part way out it swung to the passenger side some and was already torqued up. I had placed a wood wedge at the top before I started
Old May 13, 2014 | 02:40 PM
CaseyJones's Avatar
CaseyJones
That is odd. Did you remove the bolt through the snubber first or try to remove the mount from the differential housing?
Old May 13, 2014 | 04:48 PM
croaker's Avatar
croaker
Snubber bolt first maybe my bracket is bent. Diff. did move thought
To Differential in a bind
