I've been driving with EZ-EFI 1.0 for 3-4 years now. I am happy with the set, it woks fine in my car.
But I would like to know that you EZ-EFI users have set your setting to in:
Fuel pressure regulator (I have 43psi)
Fuel pressure in handheld (I have -2)
Idle AF (I have 14.0)
Cruise AF (I have 15.5, I will maybe go to 15.0/15.3)
WOT AF (I have 13.3)
My engine is a L46, 4 speed, 3.70 rear, I use my car for cursing 90% of the time.
You are running lean numbers but if plugs look good and she runs good your fine. No hesitations ? Good cold and warm starts ? Smooth accelerations from any throttle positions ? Your set
The spark plugs looks good, but to be on the safe side, then I changed to:
