L46 Compression Question
Old May 18, 2014 | 10:51 AM
Crump's Avatar
Crump
Default L46 Compression Question
I am revamping my 69 and have 195-200lbs compression on all cylinders car runs fine and does not smoke what was compression from factory Should I install rings and bearings etc while engine is out I can't find these numbers on here or anywhere else I have been told 225 on cylinders from factory but not sure
Any help would be greatly appreciated
Old May 18, 2014 | 12:34 PM
7T1vette's Avatar
7T1vette
It would not be wise to change pistons/rings without re-boring the cylinders. The present rings have worn to match the wear in the cylinders. Putting new [round] rings into worn cylinders is a recipe to lots of blow-by oil and potential disaster.
If you are not blowing oil smoke now, the rings are still sealing well. Leave them alone. I would just check a couple of rod and crank bearings, and if OK, let the engine live its useful life. You can change heads, cam, etc. without redoing the pistons/rings/crank.
If you really want different pistons, have the block re-bored.
Old May 18, 2014 | 10:40 PM
Crump's Avatar
Crump
Thanks been in the shop all day getting tranny out and getting everything ready to pull engine,had to unhook linkage from side of tranny and I believe no I know I have shifter linkage out of sink but that is another day
I also heard something hit the floor when I removed the reverse switch any ideas on that I could not find it and it had to be extremely small
No smoke; so just new valve seals and lots of shiny stuff for now
I really appreciate your reply I am new on here and this is my first Vette and maybe my last not as much room as a 55 or 57 or even a Nova
To L46 Compression Question
By Michael S. Palmer | 2026-06-03 11:00:24
