Rear VBP spring issue on 81
Old May 25, 2014 | 08:38 AM
CWerner's Avatar
CWerner
Default Rear VBP spring issue on 81
I've got a 81 aluminum rear setup on my 64 restomod. It's setup with the VBP dual mount spring. I have one continual issue that I can't figure out. I'm wondering if anyone else has the same issue.
The issue is that the black poly bushing blocks that are part of the clamping fixture on each of the dual mount locations, keep coming out. These are the blocks that clamp the spring together and hold it in position under the rear diff. It's not because the block becomes lose. I've had to replace them once a year it seems like. I'm wondering if they are getting squeezed out?
I only drive the car about 500 miles per year, only local cruising. Nothing hard.
Any thoughts?
Old May 25, 2014 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you talked to VBP?
Old May 26, 2014 | 06:12 PM
DUB's Avatar
DUB
Why not glue them to the mounting plates.
DUB
Old May 26, 2014 | 09:56 PM
gkull's Avatar
gkull
If they are anything like the fiber mono setups. The monos have a block spacer also and it comes taped on with electrical tape.
Old May 27, 2014 | 09:12 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Are these the Pads that are part of the movable plates that control how stiff the spring will be ? If so the Bolts that hold them can't be tightened very much or the blocks will warp and this might of all ready happened. The first time I drove my car I lost one of the bolts because they can't be tightened enough to stay put. So I ended up safety wiring them so they don't get lost. If I remember correctly the bushings have a peg and hole setup that needs to be aligned when they are assembled.
Old May 28, 2014 | 08:39 AM
MIKE80's Avatar
MIKE80
I had the same problem on the left rear lower block. I told VBP I was having an issue and they suggested to glue it and sent me another set of blocks. I scuffed the pad and plate with a scotch brite pad and used some rubber cement. Also, I use blue Loctite on the 4 plate bolts for each side.
Old May 28, 2014 | 08:47 AM
CWerner's Avatar
CWerner
Sounds like I'm not alone. I will order more and try the glue approach.
To Rear VBP spring issue on 81
