L46 and running 91 octane
to bring it back to perfect.
I put in about 2-3 gallons of racing fuel along with 93 octane and problem solved.
Otherwise I can detune it to run on lower octane. What fun is that?
Until someone can show me a dyno comparing an L46 on 91 Octane versus 96-98 I am NOT buying that a bone stock L46 factory set up will run on 91 or even 93 octane without detonation or a loss of power.
Yes adjustments can be made, but NO way it runs the same. Dialing in to 26 degrees total advance will improve the situation.
When I put in that little bit of racing fuel the idle smooths out, it runs cooler, there is no detonation, and my seat of the pants knows the difference big time!
Bill
I agree that it will run on 91 octane. That is not the octane an L46 or 70 LT1 for that matter was designed to run on.
If someone has dyno numbers of an original L46 running on the correct octane versus a detuned version to run on lower octane I am all ears and eyes.
All I am saying is with an L46, it must be detuned to run on a lower octane. As a result there will be some loss of performance.
I am open to be proven wrong but I need to see the DYNO numbers. Lots of folks say it will run as intended with lower octane. No one has the numbers to back it up to date.
Feel free to come check mine out with 91 octane versus 96-98 octane. Different experience all together. Bring you timing light, dwell meter, or what ever else you think you need. Mine is bone stock and will not run as intended on todays 91 octane.
There may be an all original L46 out there running perfectly on todays 91 octane set up to exact factory specs with all factory equipment installed as it left GM. I have not seen it.
Bill
I may not agree that anything higher than 93 will earn me any more "seat of the pants" power.
Adding racing fuel or jet fuel or anything else like that will certainly take away the problem, but, I like to drive this car on long trips, and most gas stations along he way don't offer racing fuel. Suppose I want to jump in the car and take a drive up the Skyline drive for a day or so, no racing fuel there. The bottom line is, the car must be tuned to run on what is commonly available.
I completely understand. I am pretty confident you can get your L46 running pretty decent on 93 octane. 91 might be a little tougher.
You are on the right track. If I take a lot of timing out it helps significantly. I never tried 91 octane, just 93.
Bill
I've put in the 160* thermostat and set timing at 26 degrees and she's running much better!
I did find out yesterday that I had the wrong stopper ring in my MSD 8571, it was the black. I did change it to the red, and a hard silver and light silver spring. (C in the MSD instructions)
That gives me 7-8 @1000rpm, and 28 @4700rpm.
I did set the timing to 7 in idle.
I do have a question, in Haynes it says:
Vacuum advance (crank degrees @ in Hg)
0 @ 7
15 @ 12
Can anyone explain what that means?
Stock Timing 1970 L46
A Initial timing @ idle 8* BTDC
B Vacuum advance 15* @ 12" Hg
C Centrifugal advance 0* @ 1000 rpm
D Centrifugal advance 10* @ 1700 rpm
E Centrifugal advance 26* @ 5000 rpm
Under this scenario max timing advance would occur @ 5,000 rpm and = A+B+E = 49* BTDC
With vacuum disconnected and plugged "all in" timing would = A + E = 34* @ 5000 rpm.
Lars timing for 1970 L46
B Vacuum advance 16*, “all in" 2" Hg below the inlet manifold reading when at idle rpm.
E Centrifugal advance 36* @ 2500/2800 rpm Needs to be "all in", distributor springs need to be changed.
Under this scenario max timing would occur @ 2500/2800 rpm and = B+E = 52* BTDC
With vacuum disconnected and plugged "all in" timing would = E = 36* @ 2500/2800 rpm.
In my case changing the vacuum can made a huge difference, I suspect it was original and had long since quit operating correctly. I’m running the cooler R43 plugs. I also changed the cooling thermostat to a lower value. I think the previous suggestion of blocking the crossover passageway under the carb is a good idea. I also removed the exhaust control valve at the right hand exhaust manifold and replaced it with a spacer. Anything which allows the engine to run cooler is going to help.
Excellent explanation in the article. Thank you.
The key is finding a machine shop to do the head work that REALLY knows what we are asking for on our cast iron heads..
It would seem to make more sense from a drivability point to put on a good set of aluminum heads rather then mess with the old cast iron heads. Have to believe there would be some additional power gains even with the stock L46 cam while eliminating the detonation issue.
Then you could clean up all that carbon build up while swapping heads.
Any suggestions on heads for just a head swap?
Bill
0 @ 7
15 @ 12
Hg is the measurement of vacuum, believe the scale is using inches of mercury .
0@7 = 0 advance of ignition timing at 7 inches of vacuum.
15@12 = 15 degrees of ignition timing at 12 inches of vacuum.
Typically to use this vacuum can you should see at least 14" of vacuum in your manifold at engine idle. It is important that the selected vacuum can is "all in" at idle rpm.
Bill
