L46 and running 91 octane
Cold air intake system instead of under hood intake air on an open filter. Keep intake temps as low as possible.
Blocking the crossover heat is one way to drop this down but requires removing the intake manifold.
richen up the mixture.
Run a colder range spark plug.
Putting on a thicker head gasket could actually make things worse or no better and you just lost CR. Getting a good squish distance of .040" is very important for combustion turbulence which reduces detonation.
So a thinner head gasket may be the direction you would want to go. Piston top shape will make a big difference. If it's a dish piston with 4 valve cut outs that is about the worst case for detonation prevention since you cannot get a good squish distance for decent quench or turbulance.
Quench transfers heat from the combustion chamber to the cooling system via the head.
Make sure your plugs do not have any sharp edges on them. Any sharp protrusion is a good starting place for undesired ignition.
If you're burning oil, eliminate it. Oil contamination to the combustion promotes detonation.
That should get you started.
Are you getting your vac advance from a manifold source?
Port vacuum and low initial timing advance numbers make the engine idle hotter making the intake charge and everything else hotter, promoting detonation.
So I took the top end apart and had the head shaved down to reduce the squish. Shaved it down to .035".
BAM! success, the detonation was gone. I was even able to reduce the octane back to 91.
I know this doesn't help you guys, but it does illustrate the importance of combustion turbulance and it's significance to proper burning of the fuel.
If I couldn't get detonation to stop and I didn't want to pull the engine I might also try installing an intake with an oil splash baffle with the crossover blocked.
The hot oil in the lifter valley can add a lot of heat to the intake manifold which then adds it to you intake charge.
If it would fit I would go with the air gap intake. Not all of our cars will fit the air gap intake. It seems to be on a case by case basis as to whether it will fit.
I've also wondered if your detonation is occuring in the area of greatest cam efficiency. In other words the period in which the engine is taking in the most air per intake event. What if you were to restrict the intake air. This would make the intake event less efficient and reduce the cylinder pressure and may stop the detonation since cylinder pressure cannot get high enough to generate it.
It might have to be done with a plate under the carb with smaller holes so that the draw on the carb is less, I'm not sure. It would of course reduce power output of the engine, but you're already doing that with timing and enrichening the fuel, so it may be worth a shot. Then you may be able to advance the timing back and set the mixture properly.
Just a thought. I've never tried it myself.
I recommend setting the timing back to factory specifications and check for detonation. If no detonation, then you can try and advance your timing for more performance if you wish.
Do the obvious and logical before yet another $50K frame off.
165 F thermostat.
8 degrees BTDC 650RPM, 18 black stopper ring, no vacuum, total 26BTDC (MSD 8571)
Cold spark plugs.
Shell classic fuel (EU 99 octane/US 93 or 94 octane)
