Alternator numbers
Now I feel better.
This is a classic case where the terminology trips up answering what should be a simple question. There were actually THREE different alternator rating during the production year- 61, 62 and 70 amps, depending on which options the car has. There was one part number rated at 61 amps, two at 63 amps and two others with 70 amps.
It appears that the 61 amp unit was discontinued at some point during the year and replaced by first one 63 amp unit, then at another point in time by a different 63 amp unit. So much for early and late.
The 70 amp cars had two different part numbers with the second number being introduced at some time during the year.
This means there's five different possibilities as you mentioned. First step is to determine which family you require.
If the car has RPO C49 (rear window defroster) or UA1 (heavy duty battery) then you need one of the 70 amp units. If no to both, you need a 61 or 63 amp unit.
As to when GM switched from one part number to another- it could have been at the very beginning of production, at the end or somewhere in the middle. If the NCRS guide doesn't give a time frame, then look at the assembly date on the alternator. If it's between two weeks to two months-ish earlier than the car assembly date, it's probably an acceptable part number.
Now I feel better.
While you're dancing with the devil will you also remember to take care of 'all original' ?!?!!
Regards,
Alan
Maybe you can arrange to have people's tongues catch on fire when they say it!
I'm sure this is a stupid question but how do you determine Heavy duty battery or not?
If the Allied-Vaughn folks have your VIN in their files, you can obtain a copy of the original dealer invoice for your 80. The invoice will list all the options installed on your car at St. Louis.
Having their tongues catch on fire is a good start, but would only happen after they've uttered the words. I'd prefer they self combust for even thinking them.
I'll add 'all original' to the list as well as 'no hit body' 'original miles' and of course 'survivor'.
Thanks again Mike. Based on what you have brought to light it appears that the date code should be 1103122 for the 63 amp. I do not have any books to check if this date code reflects an alternator being built in Nov. 79 or the months before,if you have that info that would drive the nail home as my dad would say.
The date code would be a separate stamping of a single digit for the year, a letter for the month then two digits for the day of the month. A unit built on Nov. 15th 1979 would read 9L15 for example.
Excellent that's the final piece of info I needed. Now I can start looking for that needle in a hay stack. Thanks for all your help. This vette although not one of the most popular years has become a passion for me. It scored a first place in points at the show this past weekend and I think the wrong alternator cost me a few points, anyway again thanks for answering my questions.
