Yes, bad heat treat. I experienced one of those from Crane many years back. Like 63mako says replace them all and buy good quality. A bargain isn't always a bargain.
Pulled the driver side - not as bad as the other, but a few were "mushroomed" as well. The thing that sucks is I dont want replacements if they are gonna be crap like these. Might just be best to cut my loss and go with a different brand. Any suggestions?
I've used the higher end Comps, Howards, or Manley with no issues.
Just got through with customer service at Summit - there is a reason I shop with them!!! Their customer service is bar none! They are going to take care of it for me!!!
Make sure you have hardened push rods not stock ones. I had similar issue and the stock push rods were not hardened. The ends of the push rods ended up galling the roller rockers and shortening the push rods. Made a mess of the engine, but was able to flush it all out after pulling all bearings and flushing oil galleries. Not you basic half hour job.
Unk
Being a rookie....I have put 3,000 miles on the OEM valve train with loose rocker arms that "rattled" from being set "loose" after replacing valve stem seals....but the engine never missed!
And the ball-ends looked perfect with no burrs at the oil hole. Like the members said----maybe they were too soft to start with.
I think those pushrods were not up to standards for your application. If I was you, I would buy the one piece pushrods with the rolled ends and fight with comp later. I would also pay special attention to the rocker arms. My worry would be the damaged pushrods may have made a strange wear pattern that could damage new pushrods or the rockers themselves could be compromised due to the wear.
Unk
Not sure how much metal actually made it into the engine if there was any. There was nothing in the oil except very,very fine "glitter" and most of that was in the oil filter. I put a magnet pan bolt on to see if it catches anything. I think I caught it before it could really do some damage.
@doorgunner - I think you and the others are right. Sounds like you got some good ones, though
I will be replacing the rockers along with the rods since they do have notches worn in them from the pushrods. I think the entire rocker/pushrod kit was faulty at this point.
The ball socket in that pictured rocker doesn't look right to me. Could just be my interpretation of the picture, but how do the ***** on the pushrods fit into the socket? They should fit perfectly. Test the fit with a small dab of white grease on the ball end, and then fit the two together....should be a nice even smear of grease all around the socket if the fit is good.
They looked a little worn out when I received them. I think it was a bad batch of a cheap kit. Never again will I buy them all together - seems like they add junk to complete the kit and keep the price low.
On that note, however, I am looking at the following rockers to replace these either 1.5's or 1.6's (same price). I am not sure if I need the narrower rockers with the AFR heads or not. Anyone have suggestions on pushrods in the 7.75" to 7.8" range? Will the 1.6's change the geometry enough to drop down a little shorter?
http://www.summitracing.com/parts/cc...make/chevrolet
I have used these on an economy build with no issues. AFR heads have +.100 valves. Stock pushrod length will not provide correct geometry. Combined with new rockers get the pushrod length checker, measure for correct length and confirm both exhaust and intake lengths on a couple cylinders before ordering. Your original problem could very well be from incorrect valvetrain geometry or adjustment issues. http://www.summitracing.com/parts/tfs-9001/overview/
Thanks guys - is there a specific brand I should be looking at of the 1 piece pushrods?
Wouldn't the effects of a shorter pushrod be the exact opposite in valve train wear? That would mean there isn't as much force pushing down on the valve, no?
Incorrect geometry caused increased wear at whaytever point gets loaded incorrectly. Valve guides from sideloading, valve tips, pushrods or rocker cup. You still have the same spring pressure you are overcoming but instead of pushrod centered in cup and rocker tip centered on valve your offset slightly. Might not sound like a big deal but at 2400 RPM cruise the valve is opening and closing 20 times a second with seat pressure around #100 and open pressure of over #250. This is a lot of abuse if everything is not exactly right. Incorrect valvetrain geometry is probably the most overlooked and biggest cause of excessive wear and valvetrain failure in engines that have top end components upgraded. A lot of "kits" come with pushrods but those are if your using stock components elsewhere. You change heads, gasket thickness, rockers you deviate from stock length requirements.
Im sorry, I just don't see how .100 difference would wear out the rod tips like that in only 500 miles. If that was the case, wouldn't all of them show the same kind of wear instead of only some? Not optimum performance, for sure, but that kind of damage? Not trying to argue, just trying to understand.
HUGE difference. Take a picture of your valve tips and post it. If the wear pattern on the tips of the valve is wider than .060" and not in correct place then yes you could have already put pre mature wear on the valve guides.
Valve tips and guides I can understand for sure, but pushrods? That is where I am having a hard time understanding. I will snap a few photos when I get home today. If the guides were worn, I would be burning oil, right?
Directions said to go 1/2 turn after 0 lash. Should I not? Is there a better kit I should get? I was looking at the 1.6 Scorpians...
A kit is based on OEM heads. Aftermarket heads are not OEM sizes when it comes to deck thickness, rocker stud pad location. This will change pushrod length.
Chris speaks the truth. Folks don't realize just how critical each and every component is to the engine assembly.
When I had my engine built, we installed the rotating assembly before ordering the heads and valves.
Then we measured the piston clearance before we ordered the head gasket.
Then we ordered the lifters and rockers after we mocked up the valve train and took some measurements.
Then we ordered the pushrods after we measured the SYSTEM of my rockers, my lifters, my heads, my head gasket, and my valves and the resulting relationship between my studs, my head casting, and the height of my TDC piston.
And all of this was done while also considering my cam profile, compression ratio, and spring rates.
I understand that you are where you are and would like the thing to run, but changing even one component to anything outside of stock in this entire engine system is a bigger deal than Summit/Jegs makes it out to be.
