C3 LS1 swap
Old Jun 6, 2014 | 11:29 AM
mohd2116's Avatar
mohd2116
Default C3 LS1 swap
hi guys
i have corvette 1976 with th350 trans and im planning to fix Ls1 on it but can you help me to find a ls1 exhaust manifold to be fit to fix or cheaper headers short long i don't mind !!
plz advice me
Old Jun 6, 2014 | 12:29 PM
Corey_68's Avatar
Corey_68
Most LS Vette manifolds fit, also Hookers shorty headers fit as well.
Old Jun 6, 2014 | 01:42 PM
74modified's Avatar
74modified
Many are using C5 manifolds, I am using C6. You can get pretty good flow with these manifolds. I would guess shorty headers for the same may work. Some of the shorty block hugger headers have plug clearance problems, forcing short plug use. There are also some who used F body long tube, but fitment is not always good. The custom C3 LS headers are a little on the pricey side.
Old Jun 6, 2014 | 04:55 PM
Garys 68's Avatar
Garys 68
02 Z06 flow great and will fit steering, Z bar, etc, cost under $100 used, and flow as well as headers at 350-400hp levels.
http://www.carcraft.com/techarticles...e_header_test/
Old Jun 6, 2014 | 06:58 PM
72LS1Vette's Avatar
72LS1Vette
There are a lot more headers available than when I did my engine swap. If you use a shorty header you will have more options for clearance but you will need to have down pipes fabricated. Long tube headers are going to be better for performance but your ground clearance is going to be whatever the header allows.
Rick B.
Old Jun 7, 2014 | 07:37 AM
Gordonm's Avatar
Gordonm
All good options as stated above. What are your power levels going to be. As said if you are going to be in the 350 to 400 level the manifolds will work well. Check out my post on exhaust headers. http://forums.corvetteforum.com/c3-t...es-inside.html This is a full tilt long tube no expense spared exhaust system that should be good well into the 650 to 700 hp range. I may go blower in the future but right now am in the 500+ hp range.
To C3 LS1 swap
