72 intermittent tach
Old Jun 9, 2014 | 10:54 AM
ERICHAUGUST's Avatar
ERICHAUGUST
1st Gear
Default 72 intermittent tach
My tach becomes erratic on hot days when idling in traffic and engine temperature starts to climb. Needle either bounces or drops to zero. As soon as engine temperature drops or running car on cool days ( 80 degrees or less) tach works fine. Any thoughts on what the problem may be?
Oringinal Owner, 72 LT1
Old Jun 9, 2014 | 04:34 PM
Alan 71's Avatar
Alan 71
Hi Erich,
WELCOME! FIRST POST! And an LT-! too!!!!
I replied to your thread on the DB too.
While it's certainly possible that the cable is the cause of your problem, I really think it's more likely the heat is affecting the tach mechanism.
The tachometers can be very successfully repaired… but there's $$ involved, plus getting it out and back in isn't a pleasant job.
Hoping you find a cable or cross gear problem!
We MUST have some pictures of your car…. please!
Regards,
Alan
Old Jun 9, 2014 | 04:56 PM
Gordonm's Avatar
Gordonm
I have had many a tach out and dist out and cables replaced. If the dist or cable are bad it usually is all the time. Broken pieces. The tach head could be the culprit but if there are lots of miles on the car it could be all 3 of them.
Old Jun 10, 2014 | 05:13 AM
Haggisbash's Avatar
Haggisbash
Start with the easy and disconnect the cable from the dist when everything is hot and the dist isn't working. Connect a battery drill to the cable and run in reverse (I think) to see if the tach will work, if yes its time to pull the dist and look at the cross gear drive, if no its most likely in the tach itself. FWIW if the tach has not been serviced before I would pull it, strip it and put in new lubricant before it does fail as the grease in the dist if it has not been serviced will be useless by now.
To 72 intermittent tach
