Cracking / popping sound right front
Old Jul 7, 2014 | 01:46 PM
Brcmpbl's Avatar
Brcmpbl
Originally Posted by Hpozzuoli
Check to make sure the bolts on either side of your top A arm are tight and not allowing it to move. There will be a bolt, washer, and rubber bushing on either side. Something has to be loose in that area to make that noise.
Like mentioned, check the bottom as well.
Well I think I fixed this problem - and sure enough it was simply a very loose lower control arm bushing bolt on the passenger side. I could turn the rear bolt by hand. Tightened it up and I think I'm good to go.
Another plus, I also checked all my ball joints as recommended below, and confirmed they were good.
Old Jul 7, 2014 | 03:46 PM
Phalanx_vette's Avatar
Phalanx_vette
Awesome! glad you got it worked out.
