Q-Jet Problem: No Accel Pump Shot
A leak check showed that the bowl plugs were just fine (the leaky plug thing is grossly over-rated), and the carb held fuel over night. But the accel pump did not produce a pump shot to enable the engine to start.
Disassembling the carb showed that a non-ethanol-compatible pump has been installed, and the pump was seized in the bore. So a good accel pump was installed and tested without the airhorn installed. The pump did not work, and could not be pushed down into the pump bore with the bore filled with fuel: the pump would simply compress against its spring.
The pump checkball pin and the ball were removed, and the passages were blown out and verified to be open. The pump would operate in the pump bore with the ball and pin removed. Install the ball and pin, and the pump would lock up in the pump bore…
I loosened the ball pin up ½ turn, and suddenly the accel pump circuit operated perfectly. Removing the pin and comparing it to a “real” Q-Jet pin showed that the aftermarket replacement ball retention pin that was installed in the carb was .040” too long: The pin should have an overall length of .630”, and the pin in this carb measured .670”. This additional length made the pin push the checkball firmly down into the seat, effectively blocking the entire accelerator pump fuel flow circuit.
Installation of a correct pin solved the entire problem, and the carb is now cold-starting and running perfectly.
Photo showing the correct pin (left) versus the long aftermarket pin on the right:
These aftermarket, incorrect parts are very common in commercially rebuilt carbs, but these cheap repro parts are making their way into other carbs as well during rebuilding...
Lars
