'71 Seat Release Button
Old Jun 1, 2011 | 04:19 PM
p'ville_stingray's Avatar
p'ville_stingray
2nd Gear
Default '71 Seat Release Button
Anyone know a quick and easy way to replace the seat release button on a 71?
Many Thanks.
Old Jun 1, 2011 | 05:28 PM
Alan 71's Avatar
Alan 71
Hi p,
No, there's no easy way.
The seat back cover needs to be released to get access to the screw that's on the back of the button.
To get access to the screw the seat back lock assembly needs to be unscrewed from the seat back.
Regards,
Alan
Old Jun 1, 2011 | 06:06 PM
p'ville_stingray
2nd Gear
Thanks, Alan.
Well, let the fun begin...
Old Jun 13, 2014 | 01:45 PM
Girl&herCar70's Avatar
Girl&herCar70
4th Gear
Originally Posted by p'ville_stingray
Thanks, Alan.
Hi P'ville,
I'm replacing my button and I have no idea how to go about taking off the cover/ how I should start. Could you help me?
- Do I have to take the seat out of the car or can I leave it in there?
Heather
Old Jun 13, 2014 | 01:56 PM
Alan 71's Avatar
Alan 71
Hi H,
It can be done with the seat in the car.
Remove the hard plastic cover on the lower rear of the seat back. 2 screws at it's bottom and the push the cover upward to release 2 clips at it's top.
You'll then see how the back of the seat cover is installed. It needs to be loosened to gain access to the upper part of the metal release mechanism that the button fastens to.
This isn't a quick and easy job, but certainly doable.
Good Luck!
Regards,
Alan
Old Jun 19, 2014 | 10:38 AM
Girl&herCar70
4th Gear
Originally Posted by Alan 71
Hi H,
Good Luck!
Regards,
Alan
Alan,
Thank you, your advice helped a lot; especially with the plastic cover, I would have had a hard time with that! You were right- it wasn’t quick or easy, but luckily I did get it done...
Thanks again!
Heather
To '71 Seat Release Button
