My '79 has started to yaw to the right under acceleration. When I let off the gas it will come back straight. I have looked over the suspension and don't see anything obvious that would cause it.
I had a '69 that did this and it was caused by the left trailing arm that had started to fail and would bend from the torque but that's not the case now.
Any suggestions on what I should look for?
Trailing arms.... mine did that and more.... search threads in here for more info ....
Is there a way to check the trailing arm bushings without pulling the trailing arms. I tried using a crowbar to check for play but didn't have any and from what little I can see of them they don't appear to bad.
Or should I just change them because that's most likely the problem and they're inexpensive.
The bushings are not expensive, true. But the job can be a PITA. Sometimes, the bolt that holds the front of the trailing arm to the frame rusts in place, and can be a huge nuisance to remove.
Part B of that is that the bushings often last a long time, and don't need to be replaced until you damage them while attempting to remove them.
My personal vote is your problem is a worn bushing set that holds the nose of the diff to the crossmember, or bad wheel bearings or just plain bad alignment.
Just had the car aligned when I put tires on it a couple months ago.
I'll check the differential bushings. I didn't really check around there as I figured the problem would have been in the outboard suspension.
If it were wheel bearings would there be any noticeable play in the hub?
Possibility of left motor mount separation???? Open the hood with engine running; quickly rev the engine and watch for movement. Normally, you will get a little bit of 'twist' from the engine torque with a good [rubber] mount. If you get a lot of movement, take a good look at that left mount.
What does that have to do with the car pulling to the right?
OP, my car did the same thing. I replaced the trailing arm bushings and now all is fine. Luckily the bolts came right out.
Absolutely. You may also see some strange tire wear on the offending side.
No issues with tire wear. Since there's nothing visibly wrong I can see I am going to go with changing the trailing arm bushings. That's most people's suggestion and it seems logical.
Did it do this before the tire replacement and alignment?
If not, perhaps they messed up the settings. You wouldn't necessarily see unusual wear if the tires are very new with low miles on them.
Hopefully a cheaper and easier fix than doing the trailing arms.
Trailing arm bushing problems can definitely cause steering 'wobble'. But, whether BASHCROFT knows it {or not}, a bad left mount can cause the car to tweak to the right at WOT.
You already had input on the T/A bushing issue. I was just offering another possibility for you to consider.
Bashcroft: Why are you always so disagreeable? Or are you just a 'natural' a__hole?
Big blocks were notorious for this. Mounts were fairly weak and it was pretty easy to rip the left front mount out. It would not only pull to the right but the motor would actually lift and bang on the hood if the mount was completely torn.
I have broken motor mounts in many cars (including my vette) and it never caused any of them to pull to the right or left. Why would the engine raising up an inch or two on one side have any effect on how the car tracks? Maybe you can explain the physics behind that?
something may be sloppy back there. i have a friend that thought he had big problems because on hard acceleration the car slid the rear over, and that was just a tire pressure adjustment. when mine does that i adjust the air pressure. that isn't the issue your having is it?
I'm going through that now. I was able to pull next to my black truck and see the rear wheel in the reflection. It doesn't move much, maybe a 1/2 to 3/4 of an inch going from drive to reverse.
Using a pry bar to wiggle things doesn't work well.
That's what mine does. It's not the front pulling, it's the back end moving laterally. Never thought to check the air pressure.
I know the alignment is good. I work at a dealership and the tech is is excellent.
