Horn not functioning
Old Jun 23, 2014 | 10:00 PM
BlownZ51's Avatar
BlownZ51
Default Horn not functioning
I have a 72 that I'm currently restoring and my horn is not functioning. I have no power to the green wire that goes to the horn when you press the button on the steering wheel. Has anybody had this issue or maybe know of a flow chart of where to start testing to determine the problem?
Old Jun 23, 2014 | 10:21 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Have you checked the horn relay? I had the same issue with my 72. I disassembled the horn relay, cleaned the contacts and the horn started working. I verified that the horn was good by running 12 volts directly to the horn.
Old Jun 24, 2014 | 12:25 AM
Iceaxe's Avatar
Iceaxe
Here is the troubleshooting guide I used to solve my horn issues. It's easy to follow and understand.
http://www.hunt4cleanair.net/Article..._Diagnosis.pdf
Old Jun 24, 2014 | 03:29 AM
FireballXL5's Avatar
FireballXL5
Mine on my 81 miraculously started working after replacing the rag joint... Just sayin
Dunno if that makes it ground related... Or just jostling the column around helped it out...
Old Jun 24, 2014 | 06:01 AM
7T1vette's Avatar
7T1vette
The ragjoint provides 'ground' for the horn electrical needs; +12vdc power is supplied by the horn relay and wiring to the horn button/switch.
Old Jun 24, 2014 | 06:30 PM
BlownZ51's Avatar
BlownZ51
I have not checked the relay. I wanted to start there to first confirm it was good. I wasnt sure how to check its functionality. I see the diag article that Iceaxe posted should be most helpful with checking the system. I will dig in and let you know what I find. Thank you all for the help!
Old Jun 24, 2014 | 11:20 PM
spdrcr29's Avatar
spdrcr29
Just what he said. If the horn works after jumping 12v to it, then work your way back from there to see where the issue is...
Old Oct 2, 2023 | 08:39 PM
ALLEGRO's Avatar
ALLEGRO
Amazon or Ebay
Old Oct 2, 2023 | 09:08 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Originally Posted by ALLEGRO
Amazon or Ebay
I'd bet money that they fixed it within the past nine years!!!!
To Horn not functioning
