Metal Rocker Panels (repair or replace)
Old Jul 6, 2014 | 08:27 PM
'76stingraycolorado's Avatar
'76stingraycolorado
Default Metal Rocker Panels (repair or replace)
Hello,
I'm getting ready to paint my '76. The aluminum rocker panels are somewhat bent and dinged up.
I don't really want to put these old rocker panels back on the car after a new paint job.
Should I find a shop to refurbish my old ones, or try to buy a pair of new ones?
Also, I'm buying new weather stripping, door handle and lock gaskets. Are there any other items I need to buy before the repaint? My rubber bumpers are not torn, but they are not exactly smooth either. They are a bit "wavy" in a couple places. Again, should I buy replacements or simply repaint the old ones.
Thanks for any other advice. Just trying to make sure that I'm ordering everything I need before taking on the repaint.
Jerry
Old Jul 6, 2014 | 08:48 PM
Oldguard 7's Avatar
Oldguard 7
Originally Posted by '76stingraycolorado
Hello,
Jerry
Refurbish. The new repros do not fit to the exact contours of the vehicle. When I got my car painted I had my rocker panels painted the same color as the car
Old Jul 6, 2014 | 08:50 PM
trw's Avatar
trw
I agree with Oldguard.
Old Jul 6, 2014 | 09:29 PM
'76stingraycolorado
To clarify, my rocker panels are aluminum with a chrome-ish look. Can these be painted to match the body color? What if I want to keep them the chrome/black color? Is there a way to get some of the bends/dents removed and have the aluminum polished so they look new again?
Old Jul 7, 2014 | 03:40 AM
76CSRvette's Avatar
76CSRvette
Anybody ever thought about some diamond cut metal style cut to rocker panel size.. just an idea... you could always paint Em flat black or put vinyl sticker after you fix dents. Or the best option of all side pipes. You could polish and paint strip black.
Old Jul 7, 2014 | 11:39 AM
7T1vette's Avatar
7T1vette
You can paint the stock rocker panels, but you can't do much to refurbish them. The panels have an anodized coating on them, which is much harder than the underlying aluminum. This limits 'road rash' and strengthens the part. If you grind/sand/etc on the panels, you will remove the anodized layer and the part will not be the same.
You can 'scuff' the anodized layer and paint the panels. Or, you could use a find grade of steel wool {#000 or #0000} to buff the anodized surface and clean it up some. If that isn't enough for you, buy some repro's.
Old Jul 7, 2014 | 09:37 PM
Brcmpbl's Avatar
Brcmpbl
Anyone ever tried to have the rockers re-anodized?
Old Jul 7, 2014 | 10:24 PM
Amorget's Avatar
Amorget
Do you think aircraft stripper would damage the anodization? You can see the rock chips under the latest paint that was put on it and now I am concerned about sanding them down...
Old Jul 8, 2014 | 09:40 AM
7T1vette's Avatar
7T1vette
Anodizing is a chemical process. I don't know what affect such stripping would have on them. Anodizing is also an expensive process; it might cost as much as replacing them.
If you think the little dings on an anodized part are bad, wait until you remove the anodized layer. That thing will be flimsy and soft as butter and will easily dent.
Old Jul 8, 2014 | 10:51 AM
Frank_Nesta's Avatar
Frank_Nesta
I had one obvious dent removed and polished and chromed. They look great.
There should be no reason they can not clean them up and re anodize them.
Old Jul 8, 2014 | 12:45 PM
sfallison's Avatar
sfallison
I lightly fixed the dents in both of mine, and then used my angle air tool with the red and then teal pads to strip them of scratches and the years of oxidation. After that, I used polishing compound (stick) on my bench grinder with a sisal and cloth wheel. Took a few hours, but they are mirror finished now. Have stayed that way for over a year without any sign of getting dull.
Old Jul 8, 2014 | 01:39 PM
Alan 71's Avatar
Alan 71
Hi,
The reproduction panels are slightly different than the originals. The quality and fit isn't too good.
I have a set of restored rocker panels.
The anodizing was removed, the dents removed/straightened, the pitting was removed, the 'brushed' surface was restored, and the panels were re- anodized.
The people who did this work weren't real eager to do it again.
The cost was considerable…. enough that I had to ask permission from my wife.
She and most owners would say that I'm a fool…. and that is probably true!
Regards,
Alan
Old Jul 8, 2014 | 03:27 PM
Rotonda's Avatar
Rotonda
Hello,
Jerry
Jerry,
Mine were also 'bent and dinged up'. The later C3's had a black finish on their rocker panels and I decided to refinish them to black while preserving the upper polished line for an accent. I masked the upper polished line and used sodium hydroxide to strip the balance. This is available from Eastwood under the name Anodize Remover. I then wet sanded the rocker and where bent got it into a rough shape. I used West Marine Epoxy mixed with their 410 fairing filler to fill holes, gouges and depressed areas and sanded again. I finished it off with a black epoxy primer and topped it with Eastwood's 2K Satin Ceramic Chassis Black (used to finish the black 'bumper pads' and other black trim areas).
The end product integrated well into the car, has proven durable, and the polished stripe emphasizes the C3's wasp waist design.
For what it's worth, the anodizing on the original trim was there to keep the aluminum from oxidizing/tarnishing. It was very thin and was not very hard and would be considered decorative. There are other types of anodization that can add substantial surface hardness to aluminum. ( Calaphalon Commercial cookware and Pizza Hut deep dish pans are examples)
Old Jul 9, 2014 | 12:15 AM
7T1vette's Avatar
7T1vette
Well, I've actually tried to sand and polish an old anodized part. And, much to my dismay, the end result was very weak...wanted to bend under its own weight; and it was much softer than prior to removing the anodized layer.
Cosmetic purposes only? AFAIC..... no way.
Old Jul 9, 2014 | 07:29 AM
Rotonda's Avatar
Rotonda
Perhaps the problem lies in the fact that you tried to 'sand and polish' - both of these actions remove metal which will give it less strength. These processes may also heat the metal which in turn will soften it.
You've stated your experience. Mine is that chemical removal of the anodization, wet sanding and painting did not result in any apparent diminution of the strength of my rocker panels.
To Metal Rocker Panels (repair or replace)
