zz502? crate problems
Old Jul 7, 2014 | 09:11 PM
one-72's Avatar
one-72
Default zz502? crate problems
4 miles on new crate motor and rocker arm nuts backed off can,t wait to see what comes next .All the rocker ***** are galled.and looks like they are made of the powdered metal process .Chinese ? any Ideas this is the new zz502 deluxe engine also lots of dust in the pan when i pulled it to change it upon first arrival ,anyone experiance these problems.
Old Jul 7, 2014 | 09:25 PM
Bluebuyu's Avatar
Bluebuyu
Not to start anything... But, where did you buy it?
Old Jul 7, 2014 | 10:42 PM
sweeet76's Avatar
sweeet76
If it is from China, it's the part of China that GM, Ford, and Chrysler etc. sub their parts out to. Not the part of China that everybody else uses and is referred to as Chinese junk. Seriously, I hope you get figured out.
Old Jul 8, 2014 | 03:42 AM
zuendler's Avatar
zuendler
My 502 hadn´t had this issues. And the oilpan was clean inside with only oily moisture in it.
Old Jul 8, 2014 | 07:38 AM
L88Plus's Avatar
L88Plus
Did you prime the engine or ensure you had oil to the top end before you put the 4 miles on the engine?
Old Jul 8, 2014 | 07:53 AM
7t9l82's Avatar
7t9l82
that would be my guess, when will people learn?
Old Jul 8, 2014 | 08:22 AM
one-72's Avatar
one-72
bought engine from summit from warehouse in Georgia . Of course I primed the motor and also retorqued the lower end when i changed the pan also the head bolts.And yes had good oil to the top end. The problem was easy to fix .Installed a set of Crower stainless enduro roller rockers and poly locks. Not to complane but just letting you arm chair techs.to pay close attn, to what you might see in the future. thanks 42 years building engines
To zz502? crate problems
