wiring to ac compressor question
Old Jul 8, 2014 | 10:31 PM
beautimus's Avatar
beautimus
Default wiring to ac compressor question
I have a 74 coupe that I am trying to get back together.
the plug that goes on the compressor clutch has a green wire that goes to the pressure switch plug. the other side of the pressure switch plug has the wire missing. there is a tan wire about 14 ga. that is
dangling out of the harness over near the evaporator box. could that be the wire that I am looking for?
I have a wiring diagram that I bought and had each sheet blown up to poster size. but It does not cover the ac. (can you believe it?)
if someone can look at their ac setup and check it out I would appreciate it. thanks in advance, tony
Old Jul 9, 2014 | 12:49 AM
dugsgms74's Avatar
dugsgms74
According to my 74 corvette a/c wiring diagram the two wires on the clutch are the dk. green one and a black one, the black one goes to ground. The only tan wire I see in the diagram goes to the discharge pressure switch and is in the same connector that the dk. green comes from before going to the compressor clutch.
BTW, my info comes from mitchell on demand vintage and sometimes thier info is suspect.
Old Jul 9, 2014 | 12:51 AM
Peterbuilt's Avatar
Peterbuilt
Yes, that sounds like the correct wire.
Mine has the white square paper on it to help you find it.
Old Jul 9, 2014 | 05:12 AM
beautimus's Avatar
beautimus
Woohoo ! thanks guys , that's exactly what I needed to know! thanks so much for the info!!!!
To wiring to ac compressor question
