Still having electrical problem, HELP ! !
Old Jul 9, 2014 | 09:15 PM
dpw21562's Avatar
dpw21562
Default Still having electrical problem, HELP ! !
1980 model which got a new motor installed. Used a new 140 amp. one wire alternator and can't get the thing to charge. Ran a parallel hot and ground wire to the battery. Once in a while when it starts it will spike the ammeter to 14 v. then drop to under 13 v. Alternator tested good low load 13.7 v. high load 16.2 v. In the car at battery with motor not running 11.77 v. at alt. 11.75 v. Running at bat. 11.57 and at alt. 11.5 v. Running under load at alt. 11.11v reved motor 11.35 v. at alt. Checked the grounds even cleaned the one under the battery on the crossmember. What the ??????? is going on? I don't have that much hair to pull out, help.
Old Jul 9, 2014 | 11:55 PM
ConnecticutJunkman's Avatar
ConnecticutJunkman
Take your volt meter.
Set it for volts
Take the red probe and stick it on the B+ terminal of the alt. Take the black probe and stick it to the the + of the battery. Stab it right in to the lead terminal on the battery. Dont go to the cable or bolt. Should read zero volts.
Now take the probes and go between the case of the alt and the lead on the - of the battery. Should also read zero.
If you are reading voltage then you have a bad cable or bad connection.
Another check would be to compare the readings between the B+ and case on the alt and the + and - on the battery. They should be the same. If you got 11.something on the battery and 16.something on the alt then you have a bad connection.
IF everything is the same then you have an alt issue
Are you SURE this is set up for 1 wire?
Old Jul 10, 2014 | 12:34 AM
Patro46's Avatar
Patro46
Set it for volts
What he said. It sounds like your alternator is waiting for a trigger (exciter)
Old Jul 10, 2014 | 01:07 PM
hugie82's Avatar
hugie82
Most new alternators are self exciting. Just rev the engine over 2000 rpm a few times.
You battery voltages seems very low. It should be 12.3-12.7 this might explain the 16volts . Drive it for awhile and the alternator voltage should slowly drop to 13 volts over an hour of cruising. If it stays high, above 14.5 volts. I would say try a different battery.
Your battery may be strong enough to crank the motor over but if it can't maintain or get to that 12.3 volts, the alt will think the battery is run down. That causes the regulator to go wide open on the power pumping voltage to it
Old Jul 10, 2014 | 03:56 PM
ConnecticutJunkman
Hugie the way i read his post its only doing the 16volts on the bench. In the car no matter what its only doing 11.something.
Old Jul 10, 2014 | 06:23 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
save your hair, install the correct 3 wire alternator.
the point of the 3 wire is so it can properly sense voltage and adjust charging accordingly.
1 wire is made for rods and boats and such, you car has the proper sense wiring built into it,
use it.
Old Jul 11, 2014 | 05:19 AM
dpw21562's Avatar
dpw21562
Exactly ! The battery is being tested now and going to check on that, if the battery isn't the problem, going to find a 3 wire. I've got to waste some tires.
Old Jul 11, 2014 | 08:10 PM
dpw21562's Avatar
dpw21562
Optima red top checked out good. Augh , what now? Would an engine diagnostic machine help?
Old Jul 11, 2014 | 10:20 PM
dpw21562's Avatar
dpw21562
What do you do with the two wire plug from the old three wire alternate?
Old Jul 12, 2014 | 05:41 AM
69Vett's Avatar
69Vett
plug it into the correct alternator. this is the problem.
taking for Diagnostic will be waste of time/money.
any decent electrical repair shop will tell you,
to fix your charging problems put the right alternator on it.
Old Jul 12, 2014 | 01:40 PM
dpw21562's Avatar
dpw21562
Got one coming, got my fingers crossed.
Old Jul 12, 2014 | 03:09 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Follow the instructions when installing the new alternator to keep from shorting out the internal wiring....and be sure to charge the battery for several hours BEFORE installing the new alternator.
(don't ask...... )
and be sure to charge the battery for several hours BEFORE installing the new alternator so it will get "excited" and will charge correctly.
(don't ask, again...... )
Old Jul 16, 2014 | 04:51 PM
dpw21562's Avatar
dpw21562
Default Results
Well I went and got a 120 amp 3 wire alternator, guess what, same old same old.
Old Jul 16, 2014 | 05:09 PM
69Vett's Avatar
69Vett
so with this new alternator connected all non-Original wiring removed, test 2 things.
1 what is the voltage on the output of the alternator with the engine running above 1500rpm ?
another easy test on the alternator, on the back in the center where the center bearing is located, if your alternator is working and generating current, the center area will become slightly magnetic, stick a metal something at the back of the alternator does the magnetic field pull metal object, if it does you have an open charging circuit, very possible right at your amp meter in the dash/console.
Old Jul 16, 2014 | 06:02 PM
dpw21562's Avatar
dpw21562
Voltage 12.65 volts and a bolt sticks like glue.
Old Jul 16, 2014 | 06:16 PM
69Vett's Avatar
69Vett
voltage at alternator ? correct ? not battery.
what is alternator voltage and what is battery voltage to Gnd. not to battery gnd.post.
magntic indicates magnetic feild is being generated = charging.
need schematic to follow I beleive it goes straight to AMPmeter, then thru meter and shunt,
sometimes these open, which would prevent charge from getting to the battery.
what does your ampmeter do ?
Old Jul 16, 2014 | 06:54 PM
DUB's Avatar
DUB
1980 Corvettes DO NOT have an ammeter...they have a volt meter....and it is wired completely different.
Not meaning to be a smart a$$...but reading your posts are sometimes really hard to do. You have great tips/advice but maybe reading over them before posting them. UNLESS it is just me.
DUB
To Still having electrical problem, HELP ! !
Old Jul 16, 2014 | 07:12 PM
dpw21562's Avatar
dpw21562
At alternator
Old Jul 16, 2014 | 08:34 PM
69Vett's Avatar
69Vett
my mistake I failed to read he had later model C3, thanks for the correction.
it is also why, I suggested following a schematic.
I attempt to assit people asking for help,
instead of trying to see who is the funniest off-Topic poster.
(not referring to you or this Thread)
back to OP
I think your alternator is Charging, I suspect you have an open in the charging circuit,
from the Alternator to the Battery.
Old Jul 17, 2014 | 09:24 AM
pws69's Avatar
pws69
Originally Posted by DUB
... UNLESS it is just me.
DUB
It is not you at all!!!
