C3 Rocker panel ?
Old Jul 10, 2014 | 07:27 PM
mrh747's Avatar
mrh747
Default C3 Rocker panel ?
I have a 1969 Corvette, recently purchased, with rocker panels that are not correct for 1969.
They are in nice shape. I would like to sell them but, don't know what year to reference them.
Can anyone give me tips on properly identifying them.
Max
Pic posted.
They bottom section is Black with silver top section with 6 screw holes.
There an additional screw hole two inches from the very front screw hole(bubba) I am sure.
Old Jul 10, 2014 | 07:59 PM
76CSRvette's Avatar
76CSRvette
some pics would be great to have something to reference to.
Old Jul 10, 2014 | 08:08 PM
vettebuyer6369's Avatar
vettebuyer6369
If they are the all silver ones I think it's 70-77?
Old Jul 10, 2014 | 09:01 PM
jhudec's Avatar
jhudec
If all aluminum, then I agree 70-77 because the factory holes will line up correctly. Now if they have the tabs on the bottom front, then they are possibly original 70-73, not the later 74-77 over the counter GM rocker panels without the front mounting tab.
Old Jul 10, 2014 | 09:08 PM
mrh747's Avatar
mrh747
Default C3 Rocker Panel
See photo
Old Jul 10, 2014 | 09:13 PM
jhudec's Avatar
jhudec
Looks like 70-77 that is painted to sort of look like the 2 piece 69' rocker panel would like. Need to see the back side, also does it have the tab in the lower front?
Old Jul 10, 2014 | 09:16 PM
mrh747's Avatar
mrh747
Yes it has a tab at the front end
All aluminum
Old Jul 10, 2014 | 09:18 PM
mrh747's Avatar
mrh747
The back side has a notched out section about a 12 inches from the front end
Old Jul 10, 2014 | 09:23 PM
mrh747's Avatar
mrh747
It is all aluminum
Old Jul 10, 2014 | 09:27 PM
jhudec's Avatar
jhudec
OK, you have both sides?
With the tab they are 70-73 panels.
Hard to know what the pair is worth until you strip the black paint off of them and see what the they look like. Originally they were aluminum that had an anodized finish. A nice original set are probably worth a couple of hundred bucks. I see them listed for more on ebay, but not actually selling. If they need to have dents removed and re-anodized then worth much less. Not many folks around to fix and anodize these anymore.
Old Jul 10, 2014 | 09:31 PM
jhudec's Avatar
jhudec
Just saw the info regarding the extra (bubba) hole..............That hurts the value.
Old Jul 10, 2014 | 11:00 PM
7T1vette's Avatar
7T1vette
70-77 are the same length; later panels are a little less than 2" shorter...because of the wider tires {and wheelwell} on late 70's C3's. All of them are anodized aluminum and look the same without the paint.
Old Jul 11, 2014 | 07:21 AM
Alan 71's Avatar
Alan 71
Hi max,
I agree that from a distance it looks like a 70-77 panel that's been painted.
Having the tab at the underside front makes them desirable; the extra hole lessens their desirability.
Because they're so difficult to restore well, as has been stated, their condition will impact their value.
Regards,
Alan
To C3 Rocker panel ?
