if you install with no water pump, no crank pulley.
Radiator does not need to be removed,
I highly suggest sticking a couple sheets of cardboard against the radiator,
to protect the radiator from getting banged up.
your choice on the fuel pump,
if ON the motor mounts bolt install is slightly hard.
if OFF the fuel pump install is tough.
I did my fuel pump off the car (as mentioned earlier) and it was easy. Didn't have a problem with the motor mount either, other than fighting to line it up just right, but that was on the driver's (left-hand) side of the car.
