Fast Efi Fuel line
Old Jul 16, 2014 | 11:52 AM
VonB's Avatar
VonB
Default Fast Efi Fuel line
Hello
I'm planning to mount a Fast Efi system, kit 30227, on my 72 and i have a question about the fuellines, hopefully someone can help.
Is anyone running this system with the original fuellines?, 3/8" feed and 1/4" return i think.
Thanks in advance
Old Jul 16, 2014 | 12:01 PM
zwede's Avatar
zwede
The 3/8" feed is fine. The 1/4 return is not recommended. Some have gotten away with it, but it should be the same size as the feed. You can check out the new tank/pump combo from Edelbrock:
http://www.summitracing.com/parts/edl-3605
You'd mount this in the engine compartment, and just hook it to your existing feed line. This way you do not need to run a new return.
Old Jul 16, 2014 | 12:14 PM
Shark Racer's Avatar
Shark Racer
[SR - removed link]edl-3605
I've been thinking about using that kit if I ever do EFI, but I'm wondering where I would mount it in a fully dressed AC car... since I don't have electric fans, I was thinking on the steering crossmember somewhere.
Thoughts?
Old Jul 16, 2014 | 02:05 PM
zwede's Avatar
zwede
An AC car is pretty much filled up as far as the engine compartment goes. Not sure if you could find a spot for it.
I went with a custom stainless tank from rock valley. It has the pump in it. I used the factory line as feed and added a 3/8" steel line for the return.
Old Jul 16, 2014 | 06:46 PM
Richard454's Avatar
Richard454
Also look at the Aeromotive Phantom system- neat piece.
Here's how I did mine- replaced both lines -same size. Remember at idle over 90% of your fuel is returned to the tank.
http://forums.corvetteforum.com/1587296744-post4.html
Old Jul 16, 2014 | 08:10 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have the Fast Ez-EFI kit on my car, and I used the 3/8" feed and had one of the automotive tubing vendors manufacture a pre-bent 3/8" return line for me that exactly mimicked the 1/4" return line. It fit exactly where the smaller line was perfectly.
Old Jul 16, 2014 | 08:21 PM
Shark Racer
How hard was it to replace the line on the car? Did you have the body off?
Old Jul 16, 2014 | 08:51 PM
7t2vette's Avatar
7t2vette
It wasn't terribly difficult; I unbolted the body bolts on the passenger side and also removed the rear passenger side chrome bumper and jacked up the body about 2" using a block of wood under the rocker at the middle of the door. With the help of a buddy, we were able to snake the line up the rear frame kick up pretty easily - I was actually surprised how easy it went! I also had the car on jack stands about 24" off the ground.
Old Jul 16, 2014 | 09:44 PM
diehrd's Avatar
diehrd
You have to use 3/8 return.. You can run the return along side the feed line if you want to make it super easy. And when I did mine I used the 1982 sending unit and mounted the Fast in tank pump to it.
To Fast Efi Fuel line
