Ocala Fl HELP!!!!!
Old Jul 16, 2014 | 06:26 PM
V4motorsports's Avatar
V4motorsports
Default Ocala Fl HELP!!!!!
I bought a 71 Corvette today in Tampa. Almost immediately, the car developed a miss. Cruising at 60-70 mph, it was missing (skipping) terribly. I made it to a garage and the mechanic took it for a ride with me. He suggested that I change the wires and spark plugs. We found that a couple of wires were crossed and it seemed to idle better.
We took it out for a test drive and the skip is still there. I'm trying to get the car back to CT. by the end of the weekend.
Is there anyone in the area that may be able to take a look at it for me or recommend someone I can take it to. I have no tools.
I was thinking that the timing may be off. The garage I took it to didn't have a tack/dwell or timing light.
HELP!!!!!!!!!!!!!!!
Russ
Old Jul 16, 2014 | 06:47 PM
TedH's Avatar
TedH
Corvette Shop & Supplies on Dale Mabry in Tampa has a good reputation.
http://www.corvetteshoptampa.com/Default.aspx
Van Steel in Clearwater also comes to mind. I'm sure either would be glad to check it out for you.
http://www.vansteel.com/
Old Jul 16, 2014 | 06:56 PM
C376FL's Avatar
C376FL
I agree with you on both!
Larry
Old Jul 16, 2014 | 06:57 PM
V4motorsports
Ted,
Thanks for the info. VanSteels is 2 hours south of me. Don't know if I want to try and test that again.
Appreciate your help.
Russ
Old Jul 16, 2014 | 07:08 PM
7t9l82's Avatar
7t9l82
the only guy id recommend is in west Melbourne and is farther away, why don't you call Don Garlits Museam and ask for a referral they are in Ocala and you might even get lucky and get Big Daddy to look it over, its happened before.
Old Jul 16, 2014 | 07:19 PM
V4motorsports
Now theres an idea!
Russ
Old Jul 16, 2014 | 07:21 PM
V4motorsports
Does VanSteel do tuneups also or just suspensions?
Really need to get this straightened out quick!
Russ
Old Jul 16, 2014 | 07:24 PM
7t9l82's Avatar
7t9l82
IS mystic still like it used to be? was there about 16 yrs ago and enjoyed it a lot.
Old Jul 16, 2014 | 07:35 PM
Peterbuilt's Avatar
Peterbuilt
If you have too much total timing the car can surge, disconnect and plug the vacuum advance hose and see if that helps until you find a shop with a timing light.
Old Jul 16, 2014 | 09:39 PM
TedH's Avatar
TedH
These guys may be able to help:
https://www.facebook.com/burnyzzspeedshop
Old Jul 17, 2014 | 06:29 AM
V4motorsports
Yes, it hasn't changed very much. They want to keep that small fishing village feel.
Russ
Old Jul 17, 2014 | 06:30 AM
V4motorsports
Ted, they are about 20 mins from me. Going to limp over there and see if they can help me out.
Thanks for the heads up!
Russ
Old Jul 17, 2014 | 09:04 AM
Revi's Avatar
Revi
Not wanting to sound like a jerk, but buying a 71 vette in FL and driving it to CT without any tools? Really?
Old Jul 17, 2014 | 11:43 AM
V4motorsports
Yea, really. Thats why I have towing and a credit card.
What I meant by not having any tools was, I could stop anywhere and buy the tools needed but I certainly don't have a place to work on it. I know in this day and age, there are not a lot of so-called mechanics that I would trust to work on anything of mine. I really don't like taking my car to a stealership, thats where they make all their money but not off me.
And, I thought the previous owner would have done what I asked him to do, which was to have the car looked at (tune-up, brakes, oil change, etc) so it would be road worthy prior to me leaving. That didn't happen.
Russ
Old Jul 17, 2014 | 12:18 PM
V4motorsports
Ted,
I left the hotel this morning to take the car to Burnyzz and it quit running. Pulled over and called them to see if they could tow it to their shop. I spoke with John and he recommended that I call Carter's. Carters towed it to Burnyzz and they jumped right on it. What a great bunch of people there!!!!!
I thought maybe the fuel pump had crapped out but once they started looking at it, they found:
After a few cranks
and:
So they are now cleaning out the tank,resealing the tank, blowing out the fuel lines, changing fuel filter and adding an additional filter.
Russ
Old Jul 17, 2014 | 01:57 PM
7t9l82's Avatar
7t9l82
well isn't that, special! I'm glad it is getting the attention. im sorry you weren't closer id have made a run up. good luck and let us know how the rest of the trip goes.
Old Jul 17, 2014 | 03:36 PM
V4motorsports
Burnyzz called me and said that they had drained, cleaned and sealed the gas tank. Blew out the fuel lines and replaced and added a new filter.
Less time than they thought. Great guys and if anyone gets near their shop, they need to stop by!
Now the carburetor is screwed up, keeps flooding itself out. They are trying to find another and most likely will have to have one overnighted.
I can't thanks these guys enough!!!!!
Russ
To Ocala Fl HELP!!!!!
Old Jul 17, 2014 | 05:14 PM
mrvette's Avatar
mrvette
Russ
Good, I have a full size Mystic Seaport poster on my wall now, been there for some 35 years, white border and two black hulled sailboats in the blue water.....Mystic Museum under it.....stopped by there once on the way to Martha's Vinyard, for camping, one summer, long ago....
Old Jul 17, 2014 | 05:31 PM
V4motorsports
If you make it that way again, give me a heads up and I'll show you around and maybe have a lobster dinner.
Russ
Old Jul 18, 2014 | 05:54 PM
V4motorsports
Continuing saga….
Replaced carb, replaced fuel pump. Timing is dead on. Still running like crap.
Car was full of gas when I got it but looking at the pictures above, wondering if car didn't sit for awhile and now the gas is bad?
Hopefully, shop will call again tonight or tomorrow.
Keep your fingers crossed we find it soon.
Russ
