Question/Help ;)
Old Jul 20, 2014 | 09:38 AM
Cattiva73's Avatar
Cattiva73
Default Question/Help ;)
Hello guys,
my 1973 big block is missing the extension shroud...it used to have AC but p.o. removed it.
I would like to know which extension should I put in it? is this the right part???:
http://www.zip-corvette.com/catalog/...oud-extension/
and does the fan or shroud need to come off to install it?..or is it a fairly simple job???
Thanks in advance.
Cheers
Old Jul 20, 2014 | 10:12 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This is the correct part, and its the same as the link you provided. Do you need to remove the shroud to install it.. nope, but it is a pain to install with the shroud in the car, and removing the shroud is more of a pain.
IMHO, I'd not add this. The gain is so little vs. the cost and the job to install it.
http://willcoxcorvette.com/product_i...oducts_id=2778
Old Jul 20, 2014 | 07:07 PM
Cattiva73's Avatar
Cattiva73
Thank you.
To Question/Help ;)
