Spark Plug wire routing
Old Jul 23, 2014 | 11:15 AM
gpvett79's Avatar
gpvett79
Default Spark Plug wire routing
I have installed headers on my 79 vette does any one have a suggestion, pictures or diagrams on how to best rout the plug wires
thanks very much
Old Jul 23, 2014 | 11:19 AM
MelWff's Avatar
MelWff
i have a Moroso plug wire separator kit like this, Brackets attach to outter valve cover bolts
http://www.summitracing.com/parts/mor-72133/overview/
Old Jul 23, 2014 | 12:14 PM
Flyinace3's Avatar
Flyinace3
This is how I did mine . proform seperators
Old Jul 23, 2014 | 12:41 PM
7t9l82's Avatar
7t9l82
Old Jul 23, 2014 | 12:43 PM
7t9l82's Avatar
7t9l82
Old Jul 23, 2014 | 02:20 PM
Hpozzuoli's Avatar
Hpozzuoli
My car is a 71, but here is what I did.
Old Jul 23, 2014 | 02:22 PM
Hpozzuoli's Avatar
Hpozzuoli
Other side.
Old Jul 23, 2014 | 02:26 PM
gpvett79's Avatar
gpvett79
Thank you very much for your suggestion
Old Jul 24, 2014 | 01:38 PM
gpvett79's Avatar
gpvett79
Default Heater Box
Thank you for your response I was looking at your Pictures on the way you routed your plug wires and noticed the heater box looks different can you tell me about that type box please thanks
Old Jul 24, 2014 | 01:57 PM
Flyinace3's Avatar
Flyinace3
Its a a/c delete heater box. I got it from eBay . I removed my a/c and found the original box deteriorated from oil. The a/c delete box mounts the same as the original box but its much thinner since it does not hold the evaporator. The only thing that was a little tricky was fitting the blower resister . I've saw a few different ways to mount it , most are bottom mounted but then the wiring harness needs to be lengthened. Not wanting to cut the new harness I installed I modified the resister to fit on the top. I have some pics from when I installed it if you want to check it out.
Old Jul 24, 2014 | 08:03 PM
ezobens's Avatar
ezobens
I route my plug wires the same as they did from the factory (SBC).
From the plugs down, through the sheet metal shields on the block and back up behind the heads. Factory length wires work, don't need any fancy or expensive looms and I don't burn any wires. And yes, I have full length headers.
Old Jul 24, 2014 | 09:06 PM
jbrown8238's Avatar
jbrown8238
NE Events Coordinator
If I remember correctly, I picked these up at Advance Auto, don't recall the brand though, but I like them.
Old Jul 24, 2014 | 09:25 PM
PeteZO6's Avatar
PeteZO6
So do I.
Pete
Morose spiral wires under the headers.
Old Jul 25, 2014 | 03:27 AM
mrscott25's Avatar
mrscott25
I have the same. Spectre brand. Probably not as good as the ones from summit, moroso, or msd, but surprisngly stout for the 20 bucks on amazon. Chrome is decent quality too. Worth the money. Instructions suck but easy to figure out.
Amazon.com: Spectre Performance 18483 Chrome Wire Divider: Automotive Amazon.com: Spectre Performance 18483 Chrome Wire Divider: Automotive
Old Jul 25, 2014 | 03:29 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I like going down and under like the way it left the assembly line.
To Spark Plug wire routing
